jacys Posted September 26, 2009 Share Posted September 26, 2009 Hi, How to set the force away from center for pyro? I remember it could create a sphere and use the point node to set normal force. But it cannot be create in pyro autoDopNetwork. Does someone could help me to solve it, or there is another way? Thank for help! Quote Link to comment Share on other sites More sharing options...
bhaveshpandey Posted September 27, 2009 Share Posted September 27, 2009 you could set it up using the magnet force dop Quote Link to comment Share on other sites More sharing options...
RonensArt Posted September 27, 2009 Share Posted September 27, 2009 Hi man, you can try adding Point Velocities to youre moving/not moving source and make them as you're Normals.. (If that is what you want) than, Under the Advance tab in the Pyro solver, you need to change you source (under source tab) to Point Velocities instead of rigid vel, so it will actually read it from SOPs. you can set collisions and pumps to have the same initial point vel you prepared from sop as well under similar tabs at the Advance folder of the solver, Best, Ronen. Quote Link to comment Share on other sites More sharing options...
