the spec: come up with a system that would allow to plant trees (or whatever) on any surface, and use an offset control surface to define the scale of the objects....it would allow for interactive and procedural modelling, shaping the control surface would impact the copied obj...
(hint, whenever the control surface intersects and goes below the base surf, the trees should disappear....)
it would be nice if it was robust enough to plug any poly surface as a support surface and still work...
erm...in confusion, look at the pics
have fun!
Sign In
Register
Help
MultiQuote
