Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
Juraj
convert name to uppercase
Hello,
I want to convert node's name to uppercase with On Name Changed event.
So I tried this code
node = kwargs["node"]
name = node.name()
node.setName(name.upper(), True)
But if I try to rename the node, I get error
Unknown error when generating backtrace.
And the name is converted to uppercase but from node abc becomes node ABC498 :)
Not sure where this 498 number and error come from.
I guess I am doing some beginner mistake.
Thanks,
Juraj
Share this post
Link to post
Looks fine here. Did you check what's displayed if you print the content of "name"? Maybe there is a strange sign in there.
Share this post
Link to post
Hi, I checked content of "name", it seems fine.
If I use
node.setName(name.upper(), False)
Then it works fine, but every time I change name, I get this error
Traceback (most recent call last):
  File "opdef:/Sop/jt_OUT?OnNameChanged", line 3, in <module>
  File "/opt/hfs15.5.607/houdini/python2.7libs/hou.py", line 5458, in setName
    return _hou.Node_setName(*args, **kwargs)
OperationFailed: The attempted operation failed.
Any clues?
I will test in another OS and machine.
jt_OUT.hdanc
Share this post
Link to post
Tried it on another machine with Windows and I am getting the same error. It seems like really simple task, what am I doing wrong?
Share this post
Link to post
Maybe it is related to the fact that you are changing the name in the name change event? Consider my image. I have relplaced your name.upper() with a fixed uppercase string of "ABC". I have added prints.
name = node.name()
print node.name()
node.setName("ABC", False)
print node.name()
So the first thing that happens is we print out the original name. "OUT_". Then we change the name to "ABC" successfully. Then we come back into the event (for some reason..?) and we print the name again, which is "ABC". Then we try to change the name to "ABC" but the name is already "ABC" so we get an error. If you think about it, your "OUT_" falls into the same boat. Because "OUT_" is already upper case you are essentially changing it to the same name.
What if you wrote some code to detect if the new name is the same as the old name, and only assign the new name if it is different?Untitled-1.jpg
This seems to work. Try setting your initial name to "out_" in the onCreate event and then you'll see it gets renamed to "OUT_"
name = node.name()
s = node.name().upper()
if s != name:
    node.setName(s, True)
print node.name()
Edited by Atom
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
