chumbuk Posted November 4, 2009 Share Posted November 4, 2009 Hi guys. I conceived repeat the explosion as on picture down. Here, I'll spread ideas and results. Quote Link to comment Share on other sites More sharing options...
chumbuk Posted November 5, 2009 Author Share Posted November 5, 2009 I divided whole task at parts. At first I started doing part "hell". In this part,from first test I tried two way, one with DOP-s and second only volume primitives. required to bring to readiness, but has not yet determined which method to choose for this item ... hell_v1_v2.movFetching info... hell_v1_v2_hip.rarFetching info... Quote Link to comment Share on other sites More sharing options...
lisux Posted November 5, 2009 Share Posted November 5, 2009 On 11/5/2009 at 1:31 AM, chumbuk said: I divided whole task at parts. At first I started doing part "hell". In this part,from first test I tried two way, one with DOP-s and second only volume primitives. required to bring to readiness, but has not yet determined which method to choose for this item ... Mmmm cool I like the motion of the noise. The whole motion of the DOP version is better, but the noise evolve of the volume prim version looks better. Quote Link to comment Share on other sites More sharing options...
chumbuk Posted November 5, 2009 Author Share Posted November 5, 2009 Main problem is distorting "rest" after advecting, then will use in volume shader, where it needs from noise. Sure probably can advect with high res.div. gird but I want do this with shader and "rest" field... Quote Link to comment Share on other sites More sharing options...
goldleaf Posted November 6, 2009 Share Posted November 6, 2009 Hey, this looks great. I'm still pretty green when it comes to Houdini; how did you know what DOPs to use in order to setup your solver? Was it based on physics, or just your knowledge of Houdini's micro solvers? Quote Link to comment Share on other sites More sharing options...
ykcosmo Posted November 6, 2009 Share Posted November 6, 2009 very nice!!! Quote Link to comment Share on other sites More sharing options...
chumbuk Posted November 6, 2009 Author Share Posted November 6, 2009 In this case main goal of this manipulations is get picture, but I would like to make it more or less correct, less faking. I after can try to simulate this about using more physically correct set of laws, but to start I try a more direct way(as for me...). Sorry from bad english... 02_hip.rarFetching info... advekt_fields_viz.movFetching info... Quote Link to comment Share on other sites More sharing options...
chumbuk Posted November 6, 2009 Author Share Posted November 6, 2009 in generaly as for my, main task create fractal algoritm regenerate "rest" field, that during its distortion by advect he did not very change its look Quote Link to comment Share on other sites More sharing options...
chumbuk Posted November 7, 2009 Author Share Posted November 7, 2009 (edited) little update, with more phisical sequence of create velocity field. Now velocity taken from combaine gravity( vec = (0,-1,0)) and multiply temperature field with up vector (0,1,0) its static buoyancy( temperature not advect). Then Gas project nondivergent locked inside the container divergence. In generaly this is rudimentary smoke solver stabilized in one place. But rest field dont want obey me((( more physics hip.rarFetching info... Edited November 7, 2009 by chumbuk Quote Link to comment Share on other sites More sharing options...
chumbuk Posted November 8, 2009 Author Share Posted November 8, 2009 So, after some tune, midle part with name "hell" becomes nearer to the purpose. Although there are many that still need to be done, but I'll do the second part "on hell", perhaps the most capricious in this project))) That is, I'm going to do first in general and then as necessary to supplement made. hell_v2.movFetching info... Quote Link to comment Share on other sites More sharing options...
RonensArt Posted November 11, 2009 Share Posted November 11, 2009 On 11/8/2009 at 6:34 PM, chumbuk said: So, after some tune, midle part with name "hell" becomes nearer to the purpose. Although there are many that still need to be done, but I'll do the second part "on hell", perhaps the most capricious in this project))) That is, I'm going to do first in general and then as necessary to supplement made. Hi Chumbuk does any of the rest fields was fed into the shader at last for that result? Quote Link to comment Share on other sites More sharing options...
ykcosmo Posted November 11, 2009 Share Posted November 11, 2009 looks so nice !!! Quote Link to comment Share on other sites More sharing options...
chumbuk Posted November 13, 2009 Author Share Posted November 13, 2009 Excuse my from the belated response, but life is sometimes distracting. In last result was tested by another technology, there is a rest field for the shader but still built in SOPs and Volume Vop.(if intrested attach sop_version.rar) but the search "fractal-rest" field continues. sop_version.rarFetching info... Quote Link to comment Share on other sites More sharing options...
chumbuk Posted November 18, 2009 Author Share Posted November 18, 2009 some changes... test_mix3.movFetching info... Quote Link to comment Share on other sites More sharing options...
ykcosmo Posted November 18, 2009 Share Posted November 18, 2009 I can feel the final version will come out in 2 weeks...-.-! Quote Link to comment Share on other sites More sharing options...
chumbuk Posted November 18, 2009 Author Share Posted November 18, 2009 So it's a non-commercial project, were already dozens of alterations, many technologies have tried. Microsolvers is like a drug that makes the experiment indefinitely, which is not always quickly. And in general, I'm trying to understand the nuances in dynamics and volume-primimetives in such a way. Quote Link to comment Share on other sites More sharing options...
lisux Posted November 18, 2009 Share Posted November 18, 2009 On 11/18/2009 at 1:17 AM, chumbuk said: some changes... I like it. One think I miss is that the torus like motion towars the centroid is to regular, all the volume moves at the same speed toward it goal, some variation here I think will help Good job! One day I have to take time to study all the microsolvers stuff Quote Link to comment Share on other sites More sharing options...
chumbuk Posted November 18, 2009 Author Share Posted November 18, 2009 (edited) Quote One day I have to take time to study all the microsolvers stuff study the microsolvers is the very good idea, developments and examples will share with each other))) Edited November 18, 2009 by chumbuk Quote Link to comment Share on other sites More sharing options...
chumbuk Posted November 29, 2009 Author Share Posted November 29, 2009 and again continue to experiment with our explosion, as usual it was rebuild almost everything, and added an element of psychedelics))) psyhodell.movFetching info... Quote Link to comment Share on other sites More sharing options...
nieming Posted November 29, 2009 Share Posted November 29, 2009 so cool I love it Quote Link to comment Share on other sites More sharing options...
