points filled in a deforming object
sunantha
If you don't mind can you please explain me how things work in the vopsop, esp the matrix bits.
the matrix bits are simply Transformation matrices
in compute_transform VOP, the rotation matrix is computed and applied to points then the translation vector is computed
then those informations are transfered to rest points with attrib transfer SOP
and in apply_transform VOP the Transformation Matrix is computed which consists of rotations and translation and is applied to rest points to deform them
there is also a switch in apply_transform VOP which I suppose should switch between transforms from transfer_transform_near/transfer_transform_far, but according to the condition the transfer_transform_near is never used (or i've missed something)
you can simplify this by computing whole transformation matrix in compute_transform and export it as matrix(16 floats) attribute called Transform or something
then in Attrib transfer SOP transfer just Transform attribute
and in apply_transform just multiply P with that attribute
look at the file
testRat_fix2.hipnc
look at the file
Thank you so much for your time anim, I really appreciated it.
There are a few things that I still don't quite understand.
1. What is the AttribReorient doing in there?
2. In the compute_tranform, I think I understand it better now. The only thing I don't quite get is the subtract bit.
3. In the apply_transform, what are dot and compare doing in there?
sorry to bother you again with some stupid questions.
Your help will be really appreciated.
cheers
s
it is for computing the rotation difference between the rest and deformed geometry by comparing their topology (normals,tangents, ...) and reorienting vector attributes according to that information
it's just position difference between deformed P and rotated rest P, you can imagine it as translation offset which needs to be done on the points to get to correct deformed position after being rotated by matrix
this i do not understand either, as i wrote in previous post and notice that in that post i simplified the asset so it does not contain dot and compare and many other nodes anymore (hopefully with the same effect)
Dot product of two identical non-zero vectors is allways 1 as far as i know, so i think it was ment to be used differently
Thank you anim, you've been such a great help. Thanks pclaes for pointing out to the asset.
Last but not least, thanks to everyone who's tried to help.
cheers
s
  • 7 years later...
hi all i know this is an old thread (really quite old now) but this technique by @anim is really quite effective.  I'm wondering how i would go about applying this technique to an alembic mesh i've brought in?  Right now in the network there is a channel sop thats bringing in a vertex cache from the locked geometry inside the scene.
I've setup an alembic anim and i'm just trying to plug it into the sane network with the isooffset, scatter and then the mesh deform network.
however it breaks because of the chop network outside of the setup and i dont know how to get around that.
essentially i'm after the same technique where a volume of points moves with the deforming mesh as opposed to jittering around inside.
I can lock points to a surface thats fairly straight forward but locking a 'volume' of points inside a deforming geometry seems to be quite a bit harder ?
any advice ppl?
cheers
ant
  • 1 year later...
