Different media properties
Stremik
  • 4 weeks later...
very nice....
You have to give it a try and let us all know if its really that good :). I find images made by renderers are often misleading (ie it rendered beautifully, but it took a few days to setup that scene so it worked properly and then took 36 hours to render.... ;))
Cheers
Marc
So you've used Final Render too, I take it. ;)
:P
jim.
Not I. I have cleverly avoided the anguish of trying to get these things to work. I have, however, watched with great delight the suffering of others :).
Learning from other peoples mistakes is the only way to go :P
That's it! I can't take it anymore!
I've been trying to render an image with this WinOsi renderer.
Loaded one of the supplied scenes (the one where white light is being
broken up in to rainbow colors after passing through prism) and...
It's been over an hour and a half and the image is still not finished!
Been rendering on an AMD AthlonXP 2000+; 512 MB system memory; Radeon 8500 64 MB.
The end.
  • 4 weeks later...
