yes another ocean test, at least i put a ship on top
exu
Hi guys, my first topic...
i try to use only buit in nodes... and i made in my spare time, in my old macbook pro, so
as soon i'll test using HOT, but only now i can compile it in leopard 10.5... :huh:
using bungie to deform grid, and after sent to DOP's ripple solver...
for foam particles emitted by group.
Sails are softbody POP's, and water is a choppy water displacement....
rendered in Mantra microploygon renderer ...
the Vimeo Link
http://www.vimeo.com/10955911
cheers
  On 4/15/2010 at 7:59 PM, Nibbler said:
did you wanted to make ship looks like toon, I mean I see it this way, just my opinion, don't blame on me, but in 00:15 water looks very good really
Hi Nibbler,
In fact no, don't worry about it, i don't wanna blame anyone!
it's is a W.I.P section....
So it is still under construction, i put the ship just to be a "guest" on ocean simulation and shader.... as i said, my next improve will be made a sim using HOT (Houdini Ocean Toolkit ) .... and i take your opnion for next step... if i understood ... :D
by the way i'll attach a image with my original color correct, but i think that was too dark. and the most important thing (the ocean ) was gone ...
thanks for your feedback
cheers!
  • 2 weeks later...
Hi Michael, thanks!
i'll, in fact the first thing that i try is copygeometry SOP aproach from H.O.T examples...
but i didn't a acceptable result..
what you suggest, a ray SOP ?
this is a my second attempt ... :blink:
cheers!
  On 4/29/2010 at 4:34 PM, michael said:
nice...
one thing you might want to try is animating the boat using data from the ocean surface
looking forward to seeing more!
  On 4/29/2010 at 6:27 PM, exu said:
Hi Michael, thanks!
cheers!
Hey I like the latest render. Do you have any tips for ocean shader? How are you approaching it?
Btw be careful with a ray sop. You might get unwanted slidings over the surface especially with a moving surfac that
Thanks, for tip about ray sop...
I don't think that i have any tip or trick for ocean shader, it's a basic liquid (using point color) from materials library, with small choppy water displacement and Env Map,
maybe the expression on choppy water offset can be a trick... i don't know....
i'll post the Hip file here since i can put all in same place... ( i hope until weekend's gone ) :unsure:
because i made it in 3 separate files... one for each step...and cache it, the project it's a big messy..
1- ocean ripples
2- H.O.T waves and Foam
3- Final Assembly
cheers
  • 3 months later...
Hi guys.
looks like i got a problem with the process of making ship wakes effect in houdini. First, I'm using HOT to sim a moving ocean surface( i turned on the choppy option to make the surface looks like real), and i put Outputdrive to cach this ocean surface. Then i want to use ripple solver to make the ship wake on this choppy surface......But when i sim the ship wake in the DOP network, i got unwanted slidings over the ocean surface.
I don't know why i still get unwanted slidings on the surface even through i have already cached the moving ocean. Has anybody got ideas why it always sliding?
slayerk, i have seen your ship wake effect, i like that,,, can you share some tips, have you got the unwanted slidings before?
Thanks
Edited by CSN0309
Hi, CSN0309,
You need solve ripples first, them use a (colored) group to VOP SOP to "add" Ocean Waves to Ripples Waves... you can see how you do this on files ...
cheers
Cassio
  On 8/27/2010 at 2:14 AM, CSN0309 said:
Hi guys.
Thanks
