kursad Posted June 28, 2010 Share Posted June 28, 2010 Hi I am trying to turn average normals into rotational values. I am wondering about how to achieve it. I am using attribute promote to calculate averaged point normals. Now I can access the averaged normals using the "detail" expression. I want to use these average normals to rotate the meshes. I might need to align some other objects to these rotated meshes by relying on the averaged normals of the original meshes. thanks Quote Link to comment Share on other sites More sharing options...
Macha Posted June 28, 2010 Share Posted June 28, 2010 ? Quote Link to comment Share on other sites More sharing options...
kursad Posted June 28, 2010 Author Share Posted June 28, 2010 Macha, thanks for pointing out. It looks like your VOP setup is what I need for the moment. As far as I understand this is not possible without matrix tranformations? Also is there a way to use the matrix that comes out of "align1" Vop operator directly in SOPs? I know the basic matrix math, I will try to understand what is going on mathematically inside your VOP, but would be nice to figure out direct plugging of certain matrices in SOPs. I think there is a way to do it within Python SOP. I might have some more questions later thanks again Quote Link to comment Share on other sites More sharing options...
petz Posted June 28, 2010 Share Posted June 28, 2010 you could use "dihedral" directly in sops without the need of vops. file is attached. hth. petz rotation.hipnc Quote Link to comment Share on other sites More sharing options...
kursad Posted June 29, 2010 Author Share Posted June 29, 2010 Petz, this is great. I never knew these expressions. This is another way to achieve. Thanks for the file as well. Good stuff Quote Link to comment Share on other sites More sharing options...
art3mis Posted June 26, 2017 Share Posted June 26, 2017 Hi Petz Could you briefly explain your Rotate expressions? Quote Link to comment Share on other sites More sharing options...
