Houdini 11 opengl probs
My viewport is quite "sticky". Even very simple scenes slow down when rotating and moving about the scene. This goes away when I use High Quality Lighting or switch to Hidden Line mode.
I updated my driver to the latest version but now High Quality Lighthing doesn't work at all, the screen is black.
Anybody else experience this?
graphics: Quadro FX580
driver: 258.96
OS: XP32
I also get the error below whenever I start H11 or mplayer loads.
Edited by Macha
driver: 258.96
OS: XP32
Same here using Nvidia Quadro FX 3500.
I have unchecked "Display Options -> Effects -> Material Shaders" to back to old Houdini viewport behavior.
Nothing about your others problems.
Same here using Quadro FX4600, tested with the latest drivers (258) and rolled back to 197.
When i play with smoke sims, the viewport stick to some frames during the playback.
Edited by Pazuzu
All current Nvidia drivers 256 and above do not work with Houdini 11 yet, as compiling the basic material shader fails with an internal Cg compiler error. We've filed a report with Nvidia and are awaiting a fix/advice on the matter. In the meantime, drivers between 185-197 need to be used.
It usually drops back to per-vertex (fixed function) lighting when the default shader fails to compile. But this means that HQ Lighting, Ambient Occlusion and shadows won't work. If these do work on the Nvidia 240, I'll attach that info to the bug report I've filed with Nvidia (I don't have one of those cards, myself), and hopefully that'll aid them in tracking the problem. Thanks!
Hi
Sorry, Mark. I made mistake, it's bug.
While testing, i got:
HQ Lighting - for first activation of this option - working, then if turn off(restart), black screen or segmentation fault. Restart PC and work again... not houdini
Ambient Occlusion - same as HQL
Shadows - working
Edited by ilay
I've managed to work around the issue in 256+ Nvidia driver versions, in Houdini 11.0.458.
In case anyone does GLSL work, indexing gl_LightSource[] in a for() loop, even if it's 0 to gl_MaxLights, will not work in a fragment shader in driver version 256 and above. You'll have to unroll the loop.
I got the same problem.
The viewport started to become sticky as long as I added something into the scene (just a torus and a grid).
My graphic card is Nvidia GeForce 8800 GT (on the MacPro 3,1, MacOS 10.5.8),
but I don't know how to get the info of the version of my graphic card.
but all the icons are displayed normally.
Thanks a lot, it has just helped me on a Mac. Viewports are with quick interaction again.
Not working yet, black objects when 'Material Shaders' is checked.
Driver version: 258.96
Houdini 11.0.460
Windows 7 64 bits.
Display options warning icon message:
Texture use: 0 MiB (0 maps)
Framebuffer: 31 MiB (1052x683)
Warning: Omnidirectional area shadows are not supported by DX9 hardware.
Omnidirectional point shadows will be used instead.
This is fixed in tomorrow's build, 11.0.462. The problem affected DX9-class hardware (such as the Quadro x500 series, GEforce 7x00 & 6x00, ATI X800/600/300, X1800/1600/1300). I believe you can work around it by enabling HQ Lighting in the meantime.
Great Mark, I will test 11.0.462 version.
Yes, I can work unchecking "Material Shaders" in "Display Options".
Macbook, Intel GMA X3100. In 3d viewport options "Material shaders" checkbox is disabled, but "Transparency" checkbox in same area is enabled, I have turned off transparency. But viewport is very very slow, although viewport in Houdini 10 interacts normally in scenes with simple geometry. Maybe SESI had turned on "Material shaders" by default, because when I am changing material peoperties in the parameter editor, performance are slightly slowing down. Houdini 10 viewport interacts well using this obsolete videocard.
Try setting the environment variable HOUDINI_OGL_DISABLE_FBO = 1. This will also disable color correction in the 3D viewport, but it may restore interactivity. Apple's Intel video drivers are better than Intel's own, but it's still pretty tricky to get decent performance out of most Intel GPUs.
Intel graphics aren't supported by SESI, so very little attention is given to them. Even the new Intel HD 4500 is tremendously slow with Houdini (even slower than using Software GL, ironically enough).
