Lukich Posted September 17, 2003 Share Posted September 17, 2003 Hi. I was wondering if there's a way to make an object, let's say, a curve, emit light. I'm trying to emulate one of these old electronic lamps that had a little lightning inside of them and I want the lightning to reflect off the glass surface of the lamp. I'm out of ideas on how to do it. I tried instancing the light to the points on the curve, but it turns out to be too intense even if I crank down the levels to the very minimum. Thanks a lot for any suggestions! Quote Link to comment Share on other sites More sharing options...
MatrixNAN Posted September 17, 2003 Share Posted September 17, 2003 You could write a volumetric light surface shader. Cheers, Nate Nesler Quote Link to comment Share on other sites More sharing options...
anakin78z Posted September 17, 2003 Share Posted September 17, 2003 Can you do it in comp? The easiest thing would be to render a white curve, then glow it in comp. The same could apply for your reflections. If you do decide you need actual lights, perhaps resample your curve to instance fewer lights... you probably only need a few to complete the illusion. Quote Link to comment Share on other sites More sharing options...
Lukich Posted September 17, 2003 Author Share Posted September 17, 2003 Anakin, thanks for the advice. I tried to do it in comp, but didn't think of adding a glow to the reflections. I'll try that. As for the actual lights, just to test it I resampled my curve up to points, got rid of all the lights in the scene except for one, and set value of the light and option "dimmer" to very low values (0.001), but it's still extremely bright. Is there something else that I'm missing? Thanks a lot! Quote Link to comment Share on other sites More sharing options...
MG Posted November 6, 2003 Share Posted November 6, 2003 Can you do it in comp? The easiest thing would be to render a white curve, then glow it in comp. The same could apply for your reflections. If you do decide you need actual lights, perhaps resample your curve to instance fewer lights... you probably only need a few to complete the illusion. How can you instance lights (OBJs) to the vertices of a curve (SOP)? Quote Link to comment Share on other sites More sharing options...
anakin78z Posted November 6, 2003 Share Posted November 6, 2003 There's a light instancing tutorial you can download... it's one o' the real player files. Quote Link to comment Share on other sites More sharing options...
MG Posted November 7, 2003 Share Posted November 7, 2003 From SESI? and does it work in Houdini 5.5? Quote Link to comment Share on other sites More sharing options...
stevenong Posted November 7, 2003 Share Posted November 7, 2003 Hey MG, The tutorial is available over at the Sydney Vislab. Light Instancing is a 6.0 & above feature only. Cheers! steven Quote Link to comment Share on other sites More sharing options...
MG Posted November 7, 2003 Share Posted November 7, 2003 I suspected that Quote Link to comment Share on other sites More sharing options...
melany Posted November 14, 2003 Share Posted November 14, 2003 Hi Anakin, where can i download the tutorial about the lights? thanks Quote Link to comment Share on other sites More sharing options...
