Digital Assets and the Tab menu
Ok, I've done this before but now I can't remember how.
When I create a digital asset, and then use them again, they are appearing under the tab / Menu / Digital Asset.
How do you define your own menu section for your assets? I have something called xRing and I want to put it under xPrimitives?
  • 8 years later...
It can be done but there's no direct way to access it AFAIK
hda_def = hda_node.type().definition()
tools_section = hda_def.sections()['Tools.shelf']
# tools_section.contents returns an XML string which you
# need to parse and get the value of the tab Submenu path
tools_contents = tools_section.contents()
Hope it helps :)
-J
  • 1 year later...
  • 1 year later...
How can i make a submenu inside Digital Assets to store specific HDAs?
Asset Manager - select the HDA i want - right click Type Properties - Interactive -Shelf Tools - Context - TAB Submenu Path -
currently set to Digital Assets
can i write something like Digital Assets/Custom Menu ?
