Delete particles based on ID not Point number
buran13
Hey guys,
I'm trying to clean up particle sims coming from RealFlow.
Is there a way to delete a group of particles based on their ID attribute and not the point number?
The amount of particles I need to get rid of is quite big, so it'll be really helpful if there is a way I can just select them in the viewport.
Any help is most appreciated!
Thanks
Made a quick and dirty example, notes are in the file. Hopefully it helps. :)
kill_by_id.hip
Static, thank you so much!! Exactly what I need. Although it takes a bit of time to cook with the amount of particles that I have.
Is there maybe a way to store the "kill" information in a temp file or something and use that instead of doing a loop for each particle?
Sorry if I'm asking dumb questions. I'm a noob with Houdini.
Lukeiamyourfather, thanks for the help, but I prefer to do it in Houdini. This can be very very useful not just with RealFlow particles but with particles coming from Houdini or Maya.
Thanks again
Sorry for the delayed reply... my caches came back at work :P
I made a quick python function that does that, so it only iterates once (when it's constructing the delete expression). Now it should run faster, and only requires a delete sop with a couple spare parameters. The script itself is stored in the hou.session module, accessed by going to the top menu Windows -> Python Source Editor
Keep in mind that you still need to replace the blast node with whichever one gets created, or you could chain them together, where each delete SOP references a different blast SOP.
I'm tempted to clean this up and post an otl on the exchange when I have some time. It seems pretty useful.
kill_by_id_exp.hip
kill_by_id_exp.hip
This way is actually waay slower for me. I'm not sure, but I think it's fast to store the $IDs that need to be deleted, but it takes forever for Houdini to actually delete the points. Each point has do go through this huge Filter Expression that contains all the point IDs conditions. Deleting just a 100 points or so makes it extremely extremely slow. Maybe I'm doing something wrong I'm not sure.
Thanks a lot for helping me out with this!
what's your point count? Deleting points can take a long time depending on the amount you're working with. If you're deleting thousands, then the expression will take some time to construct as well.
Keep in mind that deleting geometry can be slow because houdini has to delete it for each cook (frame).
I see what's happening. I'm not sure if there's a way to access points with specific attrib values in python (ie: specific ids) without looping through all points. At that point it may be better to look at the hdk, which I'm unfamiliar with :lol:
Using a python SOP, I think you would still need to loop through all points -> check for id -> delete. I'm not sure what the speed gains would be.
I ended up using the original setup. Takes a while to cook but very reasonable for the amount of particles I have! (about half a million)
Again, thanks a lot for your help!
  • 1 month later...
I just uploaded an asset to the Houdini Exchange that does this. With it, you can either select the points in the viewport and then run it as a tool, or simply lay it down and input the list of ID numbers. You must be in SOPs.
Its much faster that creating a long expression, because it stores the IDs in a hidden geometry.
Hope it helps.
sop_kill_particle_ids.otl
  • 1 year later...
Hope it helps.
Just wanted to thank Ryan! Pretty fast tool.
