jlmaradona Posted September 19, 2011 Share Posted September 19, 2011 Hi i have to start a project like the benjamin button titles question its, first i have to make the logo,and when this was done i have to make,the round or make the fall of buttons and project the logosorry for my english and thank every one Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted September 19, 2011 Share Posted September 19, 2011 It basicly says how it was done at the vimeo link. 1. I simulated roughly 10,000 falling buttons in Houdini using ODE, 2. then randomly assigned 20 button models to the sim objects. 3. The studio logos and mattes were projected on the end frame, (texture projection) 4. then the textures were copied to all the prior frames so they would stick to the moving buttons. 5. I rendered everything in Mantra Quote Link to comment Share on other sites More sharing options...
Netvudu Posted September 19, 2011 Share Posted September 19, 2011 (edited) That´s a really cool work. I only have one question about the method, which otherwise looks pretty straightforward. How did the projected textures were copied onto prior frames? My approach would have been baking the buttons camera-projected texture over the buttons UVs...is that what was done there? Edited September 19, 2011 by Netvudu Quote Link to comment Share on other sites More sharing options...
mawi Posted September 19, 2011 Share Posted September 19, 2011 (edited) Cant you "just" use attribute copy SOP to copy the projected UVs from last frame onto the dynamic pieces. Edit. Reading again, this might be what you intended. Edited September 19, 2011 by mawi Quote Link to comment Share on other sites More sharing options...
Netvudu Posted September 19, 2011 Share Posted September 19, 2011 (edited) mmm...indeed. It sounds like something that would work I have to try it. Let´s see if I can find 20 spare minutes at some point today. (silly work ) EDIT: no, I was speaking about actual baking without the Attribute copy, which is a faster way in my opinion. So in fact your idea is a good one. Edited September 19, 2011 by Netvudu Quote Link to comment Share on other sites More sharing options...
eetu Posted September 19, 2011 Share Posted September 19, 2011 Heh, I remember doing this immediately after I saw the credits first time I had a Texture SOP, in camera projection mode, and I just locked the SOP after the buttons had settled. After that I had a Point SOP copying the UVs from the Texture SOP to the DOP Imported geo. ($MAPU2 etc for the texture). Quote Link to comment Share on other sites More sharing options...
jlmaradona Posted September 19, 2011 Author Share Posted September 19, 2011 OK thank for the advice about UVS and projections i will try tonigth Quote Link to comment Share on other sites More sharing options...
Netvudu Posted September 19, 2011 Share Posted September 19, 2011 I just did it with the Copy Attribute method. It works flawlessly. Quote Link to comment Share on other sites More sharing options...
eetu Posted September 19, 2011 Share Posted September 19, 2011 (edited) Actually, this would've made a nice Odforce Challenge, it would be nice to see in how many different ways this could be done Edited September 19, 2011 by eetu Quote Link to comment Share on other sites More sharing options...
jlmaradona Posted September 19, 2011 Author Share Posted September 19, 2011 HI Netvudu (Javier),i dont found the way to work fine , can you send me a hip with a easy simulation. you did Javier,veo eres de España y perdona por escribirte en Español,pero no me sale bien la simulacion de los botones,bueno lo hago con circulos,si me dejas probar la tuya te lo agradezco Un saludo Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted September 19, 2011 Share Posted September 19, 2011 HI Netvudu (Javier),i dont found the way to work fine , can you send me a hip with a easy simulation. you did Javier,veo eres de España y perdona por escribirte en Español,pero no me sale bien la simulacion de los botones,bueno lo hago con circulos,si me dejas probar la tuya te lo agradezco Un saludo Write out simulation geo. Use UVTexture and project from camera. Lock the node at whatever frame you want it to perfectly align. Use attributecopy to copy the UVs back to the written out geo. Quote Link to comment Share on other sites More sharing options...
Netvudu Posted September 19, 2011 Share Posted September 19, 2011 Sure. Here you go. This version looks quite worse because I just used 800 boxes, as opposed to the 10,000 buttons that they used in the original, but this one is just for testing purposes. I also used the Mandril default texture so you (or anybody else) can check it easily. Warning! Spanish ahead Aquí tienes la escena. Sólo hay 800 cajas en lugar de 10,000 botones, así que tiene claramente peor aspecto que el original de Digital Domain, pero sólo lo he hecho para comprobar que funciona. Sería muy fácil aumentar el número o poner otro objeto en lugar de las cajas, ahora que ya está. Lleva la textura del Mandril incluída en la instalación de Houdini, para que no te de problemas, aunque puedes poner cualquiera desde el material. Cualquier pregunta, ya sabes, que los comienzos son complicados. RD_Test_LockedGeo.hipnc Quote Link to comment Share on other sites More sharing options...
brianburke Posted September 19, 2011 Share Posted September 19, 2011 Write out simulation geo. Use UVTexture and project from camera. Lock the node at whatever frame you want it to perfectly align. Use attributecopy to copy the UVs back to the written out geo. ha ha, cool rage texture. Quote Link to comment Share on other sites More sharing options...
chimeric Posted September 20, 2011 Share Posted September 20, 2011 This effect is really great, gracias Netvudu for the file!! Quote Link to comment Share on other sites More sharing options...
Erik_JE Posted September 20, 2011 Share Posted September 20, 2011 ha ha, cool rage texture. Thanks hehe. It reflects my current state of mind pretty accurately Quote Link to comment Share on other sites More sharing options...
jlmaradona Posted September 20, 2011 Author Share Posted September 20, 2011 THANK YOU FOR THE FILE,I WILL WORK TONIGHT JAVIER,MUCHAS GRACIAS,COMO DICES ALGUNOS COMIENZOS SON DIFICILES,SEGUIMOS EN CONTACTO Y ME REITERO MUCHAS GRACIAS Quote Link to comment Share on other sites More sharing options...
Taikels Posted January 13, 2013 Share Posted January 13, 2013 Thanks for the file Javier ! Quote Link to comment Share on other sites More sharing options...
Netvudu Posted January 14, 2013 Share Posted January 14, 2013 Quote Link to comment Share on other sites More sharing options...
