Surface from pointcloud?
Macha
Does anybody know of a way to create a clean, single-sided surface from a pointcloud? I am not talking about particlefluid surface or metaballs or anything like that. Just a thin, one-sided, clean, accurate surface from a complex multi-zillion point cloud.
Edited by Macha
Have you tried Isosurface? A bit messy but could be a good starting point...
somewhere on odforce there was a thread on wrapping meshlab functionality
within houdini using a unix SOP (??)
I've used meshlab for something pretty similar it gets good results but
no undo options last time I checked (are they there yet??)
Edit: meshlab via unix sop
Edited by bhaveshpandey
The problem with sdf and all these volume methods is that you get an offset surface and if you have nonclosed geometry you get doublesided walls. It is also very hard to get good sdf from complex geo. Meshlab funcionality inside Houdini would be great!
That are interesting links, thank you both!
Macha, if you need it badly & now, you could try a dirty hack of applying uvs to points, triangulate in uv space (Triangulate2D) and back to Cartesian, basically asking Delaunay to work in some parametric 2D space of a point cloud. Unless you can't have nice 2d space... (afaik slightly stretched is fine).
