magneto Posted March 13, 2012 Share Posted March 13, 2012 Just wondering if it's possible. If it's possible, it would be faster than the provided POPs, right? If that's the case, then wouldn't SESI do this before? I am asking because I read here that POPs aren't threaded, or was it SOPs? Just curious about people thoughts on this matter Quote Link to comment Share on other sites More sharing options...
Tom Posted March 13, 2012 Share Posted March 13, 2012 From docs: "The VEX POP allows you to do almost anything that POPs can do themselves. It is possible to write one single VEX function which performs the task of many POPs. Because the VEX code is localized to one single operator, the VEX code will typically run faster than a network of POPs." http://www.sidefx.com/docs/houdini12.0/vex/ 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted March 13, 2012 Author Share Posted March 13, 2012 That's amazing. There must be some Houdini experts who wrote their own POP collection I am sure then Quote Link to comment Share on other sites More sharing options...
lisux Posted March 13, 2012 Share Posted March 13, 2012 That's amazing. There must be some Houdini experts who wrote their own POP collection I am sure then Yep you are very right here 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted March 13, 2012 Author Share Posted March 13, 2012 Very inspiring I am not sure about the functionality of the built-in POPs, but are there operators to do inter-particle collision, avoidance, attraction, find target, go to rotation, etc? Kinda like particle flow's operators? http://www.orbaz.com/documentation/particleflowtools/box2/ I like that in Houdini you can just make your own POPs using the infinitely powerful VEX/VOPs. Also are the built-in POP's threaded? I saw the H12 video where it was shown as half of them are, if I recall correctly. Quote Link to comment Share on other sites More sharing options...
tjeeds Posted March 13, 2012 Share Posted March 13, 2012 I am not sure about the functionality of the built-in POPs, but are there operators to do inter-particle collision, avoidance, attraction, find target, go to rotation, etc? Goals are really pretty simple, it's just aiming the velocity or acceleration toward a goal point. There's not a stock POP for it specifically, you could use expressions in a Velocity POP or something, but it's easiest to just do it in VOPs. Rotation is avaliable through the Rotation and Torque POPs but you can allso modify the rot quaternion attribute directly in VOPs. Also you can raycast with the Intersect VOP so you can have Ray SOP-like functionality in POPs. The key to a lot of this, is that any VOP that wants a geomtery file can be fed a sop node path as long as you put op: in front of it. Like op:/obj/geo1/OUT As far as I know there's no easy way to do inter-particle collisions, you can use the Interact POP to create interparticle forces (avoidance, attraction) but spherical or ellicptical collisions are something I've always wished for in POPs. Also missing is the ability to query the incoming geometry as a point cloud, you can access SOP geometry, but not the incoming POP geo. Knowmsayin'? Also you're confined to excrutiatingly slow expressions for finding the nearest Primitive and Paremetric uv position from a particle, this is handy stuff but it's just not practical to access because it's not a vex function. Oh and if anyone could correct me on any of this I'd be their best friend forever! 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted March 13, 2012 Author Share Posted March 13, 2012 Thanks tjeeds, this is the sort of stuff I am looking to hear from expert users. By not being able to access the incoming pop geometry, do you mean the instanced objects onto the particles? I am sure there are some people here who must have coded some nifty POPs that does the stuff you are talking about Quote Link to comment Share on other sites More sharing options...
vi_rus Posted March 13, 2012 Share Posted March 13, 2012 You can even recreate your own particle system with sop solver! I usually do this if I need a total control of particle behavior. In this case you can use full power of sop context. sop_solver_particle_system.hip 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted March 13, 2012 Author Share Posted March 13, 2012 Thanks vi_rus, that looks amazing. What's the advantage of using the sop context for particles? Just wondering Quote Link to comment Share on other sites More sharing options...
vi_rus Posted March 13, 2012 Share Posted March 13, 2012 Thanks vi_rus, that looks amazing. What's the advantage of using the sop context for particles? Just wondering 1. You can use ALL sops nodes. 2. You can use point cloud feature in vex. 3. You don't have to use a poppoint() expression for custom variables. It's really mad me in pop) 4. It's fully custom system where you can control absolutely everything. And maybe it will be faster than pop. But I don't sure. I think there is exist and others points for this) But pop is more simpler than that solution. And if you need to do a simple simulation then better to use pop context. It was just my point) 1 Quote Link to comment Share on other sites More sharing options...
tjeeds Posted March 13, 2012 Share Posted March 13, 2012 Ah yeah, this too. Excellent point. I generally only use the SOP solver if I need a SOP node though, because most point operations that you can do with a SOP you can also do in a VOP POP. Also it takes care of all the acceleration>velocity>position integration and handles oversampling for you. Basically, with a few exceptions, POPs will be faster and more straightforward. 3. You don't have to use a poppoint() expression for custom variables. It's really mad me in pop) I feel your pain, but I just wanted to point out that I've never seen a situation where you must to use this expression. VOPs supplies you with the Import Attribute node if you need a specific point and if you just need to map a local variable the Attribute POP with Write Values turned off will handle that with ease. 1 Quote Link to comment Share on other sites More sharing options...
vi_rus Posted March 13, 2012 Share Posted March 13, 2012 I feel your pain, but I just wanted to point out that I've never seen a situation where you must to use this expression. VOPs supplies you with the Import Attribute node if you need a specific point and if you just need to map a local variable the Attribute POP with Write Values turned off will handle that with ease. Sure, if you're using only VOP there is no problem with this issue. Pop context is good but I just wanted to say that in some cases I prefer to use this technique) Quote Link to comment Share on other sites More sharing options...
magneto Posted March 13, 2012 Author Share Posted March 13, 2012 Thanks guys, great discussion. Another question: is there a different between POP's VOPs and SOP's VOPs? Because vi_rus you said "You can use point cloud feature in vex.", so they are not available in POP VOPs? I was thinking it's more of less the same in terms of functionality. Also another thing I am wondering is if you use SOPs for particles, do you have your own particle SOPs to make things quickly? I imagine it would take a lot of time to redo all those steps from scratch to add force, drag, velocity, etc. Like in your example scene, you have digital assets to create them similar to POPs, right? Quote Link to comment Share on other sites More sharing options...
vi_rus Posted March 13, 2012 Share Posted March 13, 2012 There is a thread about point cloud in vop pop. Also another thing I am wondering is if you use SOPs for particles, do you have your own particle SOPs to make things quickly? I imagine it would take a lot of time to redo all those steps from scratch to add force, drag, velocity, etc. Like in your example scene, you have digital assets to create them similar to POPs, right? If I need to do some vop stuff I usually do this pretty fast, so it's not a problem for me) 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted March 13, 2012 Author Share Posted March 13, 2012 This is so inspiring, Peter's post on recreating all POPs using SOPs. Also scrubbing particles from the timeline is awesome. There is so much to learn Quote Link to comment Share on other sites More sharing options...
edward Posted March 14, 2012 Share Posted March 14, 2012 You can even recreate your own particle system with sop solver! I usually do this if I need a total control of particle behavior. In this case you can use full power of sop context. +100 Quote Link to comment Share on other sites More sharing options...
magneto Posted March 14, 2012 Author Share Posted March 14, 2012 Actually something else I don't understand is, how is the SOP version of particles allow scrubbing in the timeline, but POPs do not? Is it because SOPs are caching? Isn't particles dependent on previous state, but SOP particles allow free scrubbing backwards and forwards? Quote Link to comment Share on other sites More sharing options...
vi_rus Posted March 14, 2012 Share Posted March 14, 2012 Actually something else I don't understand is, how is the SOP version of particles allow scrubbing in the timeline, but POPs do not? Is it because SOPs are caching? Exactly! And that's one more advantage of this method. Quote Link to comment Share on other sites More sharing options...
magneto Posted March 14, 2012 Author Share Posted March 14, 2012 Thanks but how does that work? I don't understand why this difference happens. Quote Link to comment Share on other sites More sharing options...
gaurav Posted March 14, 2012 Share Posted March 14, 2012 Thanks but how does that work? I don't understand why this difference happens. Its the Dops which provide environment for caching and sop solver inside it just uses that. You can also cache your particle system using pop solver inside Dops. Set up pop object and pop solver inside the dops and point the pop solver to your particle system. Particles will be cached next time you play the dop sim. Cheers, Quote Link to comment Share on other sites More sharing options...
