anupamd Posted June 21, 2012 Share Posted June 21, 2012 So, Ive been struggling trying to figure out a good pipeline for using pyro with scenes of different scales. If I have a pyro setup that works great and looks perfect. Now I drop in a scene and that scene is 100 times bigger than my setup. I found that its a lot easier to scale down my scene to the size of my pyro emitter/container , than try to somehow scale up my pyro grids/ noise scale..etc. So my question is, if I wanted to scale up my pyro setup, is there an "easy" way to do this that would reliably scale my pyro setup without changing the behaviour of the sim? I'd especially love to hear from those of you who use pyro in production what kind of pipeline works for this. -A Quote Link to comment Share on other sites More sharing options...
bunker Posted June 22, 2012 Share Posted June 22, 2012 (edited) You could create a parameter called "scene scale" and link it to all the relevant parameters in the solver (noise frequencies, fields div sizes, ...) - a bit painful - Or you can do it quickly with 2 transform nodes: scale down your sources, and scale up the output of your sim. Edited June 22, 2012 by bunker 1 Quote Link to comment Share on other sites More sharing options...
Benyee Posted June 28, 2012 Share Posted June 28, 2012 Some trick is scale scene,charactors,motions...etc to a standard(your favorate) effect space scale. Quote Link to comment Share on other sites More sharing options...
loudsubs Posted June 28, 2012 Share Posted June 28, 2012 I've been encountering this problem lately. The problem with scaling down a camera is that it messes with the volume step size of the render, so your viewport and the render can look drastically different. So the way I've been dealing with geo that comes from maya (which is usually 100x too big), is create a null, scale it down to fit your scene. parent your imported camera (and geo) to the scaled null. create a blend node parented to the camera. turn off sx sy and sz, this way the blend is only picking of the transforms and rotations, not the scales. copy the parented camera, set transforms, rotations, and scales to defaults, so it inherits movement only from its parent. parent it to the blend node. so you should have 4 nodes in the chain: null (scaled down) camera (original) blend (turn off scaling) camera (transforms, rots, and scales set to default) scene geo should be parented to the top null render using the bottom camera in the chain Quote Link to comment Share on other sites More sharing options...
anupamd Posted June 29, 2012 Author Share Posted June 29, 2012 Hmm in not really sure what you are accomplishing using the blend node? could you clarify? Ive just been scaling the whole scene down by putting everything (geo/cam) into a subnet and scaling the subnet. As for the stepsize, cant you just decrease/increase the stepsize to your liking in the mantra/sampling area? I've never gotten my pyro in the render to match the viewport.. well not exactly accurately, and im not really sure if thats so important as you have a lot of control in the shader anyway. I've been encountering this problem lately. The problem with scaling down a camera is that it messes with the volume step size of the render, so your viewport and the render can look drastically different. So the way I've been dealing with geo that comes from maya (which is usually 100x too big), is create a null, scale it down to fit your scene. parent your imported camera (and geo) to the scaled null. create a blend node parented to the camera. turn off sx sy and sz, this way the blend is only picking of the transforms and rotations, not the scales. copy the parented camera, set transforms, rotations, and scales to defaults, so it inherits movement only from its parent. parent it to the blend node. so you should have 4 nodes in the chain: null (scaled down) camera (original) blend (turn off scaling) camera (transforms, rots, and scales set to default) scene geo should be parented to the top null render using the bottom camera in the chain Quote Link to comment Share on other sites More sharing options...
efx Posted June 29, 2012 Share Posted June 29, 2012 Hi, I think to change camera and light scale is not good idea. Especially if you r working on stereoscopic project. I did not spend much time but I think you can just scale your volume(smoke/fire whatever), Just need to set right volume step size and shader attribute such as Density / shadow density. It's good to set volume step size per volume/object. I attached file and pls compare the both montra. Should look the same. Cheers volume_scene_scale.hipnc Quote Link to comment Share on other sites More sharing options...
loudsubs Posted June 29, 2012 Share Posted June 29, 2012 Hmm in not really sure what you are accomplishing using the blend node? could you clarify? The blend is there because you can turn off sx, sy, sz... so the bottom camera object doesnt inherit the scale parameter values of its parents (which will probably be something like .01 if you're scaling down). You just want it inheriting the scaled transforms and rotations, not the actual scale parameter. Alternatively, instead of a blend node, you could put another null and scale it back up by whatever you scaled the top one down by. The point is to get the actual scale of your rendering camera back to 1 (even though the transforms and rotations are being scaled down). Yeah this is a hack, and its definately better to avoid scaling your camera. But when thats not possible for whatever reason, this method has helped me not have to recreate a sim from the very begining, once I get some imported geo or camera that is using different world units from my scene. Quote Link to comment Share on other sites More sharing options...
anupamd Posted July 12, 2012 Author Share Posted July 12, 2012 infact the scaled camera really does cause issues with the sim/pyroshader. So I used your technique and it works great. Thanks a bunch! Quote Link to comment Share on other sites More sharing options...
hatrick Posted July 23, 2012 Share Posted July 23, 2012 (edited) Loudsubs! you saved my day ! Edited July 23, 2012 by hatrick Quote Link to comment Share on other sites More sharing options...
