sly Posted August 22, 2012 Share Posted August 22, 2012 Hi, I woul like to know if you have good tips/ideas for creating shapes outlines , i just can't find a proper way to do this , i posted an exemple of the shape i need some outlines if someone want to take a look. thank you. Sly. forOutline.hipnc Quote Link to comment Share on other sites More sharing options...
gui Posted August 22, 2012 Share Posted August 22, 2012 Hello! I didn't understand. Do you want to render the outlines? You can use the "wren" renderer or try using some frenel shader to mimic that. Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted August 22, 2012 Share Posted August 22, 2012 Hi, I woul like to know if you have good tips/ideas for creating shapes outlines , i just can't find a proper way to do this , i posted an exemple of the shape i need some outlines if someone want to take a look. thank you. Sly. Ends sop with unroll selected - like in attached file? forOutline_ends.hipnc Quote Link to comment Share on other sites More sharing options...
sly Posted August 23, 2012 Author Share Posted August 23, 2012 sorry , if was not understandable . i attach a pic , on the left is what i have in houdini , and on the right is what i like to have . i don't find a proper way to do it in houdini Quote Link to comment Share on other sites More sharing options...
J.Santos Posted August 23, 2012 Share Posted August 23, 2012 Hi! if you have the shape image already, you can use a Tracer SOP... and reduce the number of points it will create... Quote Link to comment Share on other sites More sharing options...
jkunz07 Posted August 23, 2012 Share Posted August 23, 2012 sorry , if was not understandable . i attach a pic , on the left is what i have in houdini , and on the right is what i like to have . i don't find a proper way to do it in houdini Ohhhhh, maybe check out this? http://www.creatogether.com/hou-curveoffset/ Quote Link to comment Share on other sites More sharing options...
ryew Posted August 23, 2012 Share Posted August 23, 2012 (edited) So you are trying to get two lines around each shape? It would help clarify what you're after if your images were shaded to identify what is solid geometry and what is a line Edited August 23, 2012 by ryew Quote Link to comment Share on other sites More sharing options...
zarti Posted August 23, 2012 Share Posted August 23, 2012 try Sweep SOP .. ( if i understood you this time correctly ) .cheers Quote Link to comment Share on other sites More sharing options...
sly Posted August 23, 2012 Author Share Posted August 23, 2012 (edited) Ohhhhh, maybe check out this? http://www.creatogether.com/hou-curveoffset/ thank it s exactly what i wanted .Sorry for all if i badly explain what i wanted to do . Unfortunaly , these otl , doesn't work with the shapes i have . finally i find a pretty easy solution via the extrude node . here the file ( if it can interest/help someone) createOutlines.hipnc Edited August 23, 2012 by sly Quote Link to comment Share on other sites More sharing options...
