magneto Posted October 8, 2012 Share Posted October 8, 2012 Hi, I know Houdini doesn't have convex hulls but does it have functionality to create 2d convex hulls, perhaps some SOP magic? Quote Link to comment Share on other sites More sharing options...
kgoossens Posted October 8, 2012 Share Posted October 8, 2012 triangulate2D node 1 Quote Link to comment Share on other sites More sharing options...
eetu Posted October 8, 2012 Share Posted October 8, 2012 I know Houdini doesn't have convex hulls Have you tried Tetrahedralize SOP? If you need a 2d hull you should be able to just flatten that. 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted October 8, 2012 Author Share Posted October 8, 2012 Thanks guys. I tried Tetrahedralize SOP, but it gave me result that didn't seem like it formed a surface when I viewed it. Basically the points (no prims) are already flat Maybe this is an issue? I just tried Triangulate SOP and while it looks correct, I still don't want to have all the internal points, but just the closed outline polygon/curve. Can I achieve that? As a sample object, try it on a teapot and flatten it. My points are already flat, but you can do this just to see similar results as me. Quote Link to comment Share on other sites More sharing options...
kgoossens Posted October 8, 2012 Share Posted October 8, 2012 Yes divide node remove shared edges 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted October 8, 2012 Author Share Posted October 8, 2012 (edited) Thanks Kim, that's great, really does the trick EDIT: Btw the help file mentions this for the Tetrahedralize SOP: "Also, it can only return a convex hull for sets of points with valid tetrahedralization. So no primitives will be returned for things such as points on a 2D plane. However, you can special case these cases and for example use Triangulate2D followed by Divide and turn on Remove Shared Edges." Wish I could use that one because it seems faster than Triangulate2D which takes 1.6s for 20000 points Edited October 8, 2012 by magneto Quote Link to comment Share on other sites More sharing options...
