VOPSOP viewing data
breadbox
is there a way to directly view the information passed through a VOP network?
like a spreadsheet editor or a details view?
for example If I multiply point position by a constant vector is there a way to view the output vector?
I can plug the output vector into the point position and view the result in the viewport, but would like to see it numerically represented in a list or graph?
Ultimately I'm trying to export / convert euler rotation values. Is there another method for output so I can output the result of a VOP network but not through point positions, like a custom variable or attribute? I could maybe do color or normal but is there a way to add custom?
Also because vectors and floats can be easily mapped to color so that I can view in the details view, but things like matrix how to easily view those? Currently I'm converting the matrix to a float and viewing that but its slow to map the outputs.
Edited by breadbox
There's a VOP called Add Attribute. Be sure to enter a local variable name if you want to be able to access the attribute once back in SOP with expressions.
http://www.sidefx.com/docs/houdini12.1/nodes/vop/addattrib
There's the spreadsheet view back in SOP which will show the value of attributes per point (or primitive, vertex, whatever). Right click a SOP node and select "Spreadsheet" from the list to get it.
