sly Posted November 27, 2012 Share Posted November 27, 2012 (edited) ih there, is there a way to store the value of the current frame ( $F) in an attribute . for example , i have a grid with some animated points , i want to store the value of the frame at which the points begin to animate (something a little like a birth time value) hope i m clear. cheers. Edited November 27, 2012 by sly Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted November 27, 2012 Share Posted November 27, 2012 For this I think you'd need to use the Solver SOP. If you try to change the attribute just with a AttributeCreate SOP it will always update each time the network cooks instead of just once on a previous frame. Quote Link to comment Share on other sites More sharing options...
sadhu Posted November 27, 2012 Share Posted November 27, 2012 One of the solutions. birth_frame.hipnc Quote Link to comment Share on other sites More sharing options...
Mzigaib Posted November 27, 2012 Share Posted November 27, 2012 ih there, is there a way to store the value of the current frame ( $F) in an attribute . for example , i have a grid with some animated points , i want to store the value of the frame at which the points begin to animate (something a little like a birth time value) hope i m clear. cheers. You can do it with points in POP's. I hope it helps. frame_stamping.hipnc Quote Link to comment Share on other sites More sharing options...
sly Posted November 27, 2012 Author Share Posted November 27, 2012 (edited) @sadhu : thanks . it works very well @Mzigaib : i m searching for a solution that dont use particles Edited November 27, 2012 by sly Quote Link to comment Share on other sites More sharing options...
