nate.usiak
Hello all, this is my first time posting on here so greetings. This is a cross post also on the Houdini forums here:
http://www.sidefx.com/index.php?option=com_forum&Itemid=172&page=viewtopic&t=27451
I have been working on a tool that takes an input curve and adds velocity to it for use in a Pyro sim (also FLIP but first getting it to work with Pyro). I have been working on this tool to help give the artist an easy way to direct a Pyro sim along a curve.
Here is an example of how it is currently working:
https://vimeo.com/55189800
Here is a screen cap of how I have implemented the use of the tool:
https://vimeo.com/55238678
I'm also including my otl and an example file.
I would like any feedback as to ways to improve the tool or other/better ways of accomplishing similar effects. I greatly appreciate it.
Thank you much.
example.hipnc
NU_curveToVel.otl
  • Like 5
After reworking the tool in Vops I am very pleased with how much faster it is cooking. I am instead within the Vopssop taking normal tangents and displacing the points along those vectors which in turn gives me more control.
I still of course welcome any feedback, suggestions or critique.
Thank you.
I have not posted any more tests yet but a screen cap of the tool use found here:
https://vimeo.com/55833089
post-8826-0-47242700-1355806501_thumb.jp
post-8826-0-44943700-1355806502_thumb.jp
  • 8 months later...
  • 1 month later...
Get a point cloud along your curve, there are many ways you can do this - I guess the easiest is to build a a tube using your curve (polywireSOP) and scatter points inside (PointsFromVolumeSOP) and then use a VOPSOP or PointWrangle to get the position of your each point and cross product this with the position of closest point in the curve (PointCloudOpen and PointCloudFilter) - Normalize both before the cross product.
TIP: You can use a ramp for distance from the center to control how strong your vortex will as getting closer to the center.
bumpin this! :D
can anyone explain how you would add a vortex throughout the curve?
I've been working on a project that required something similar to Nates tool, with a vortex. I think its even faster when you use volumes from the start, instead of converting vector point attribs into volumes. Here's quick example of how I did it.
vel_vortex.hip
  • 6 months later...
  • 4 months later...
Thanks a lot for this Nate
I was trying to recreate the tool, and I think I've done it completely, but whenever I add points on my top-level ramp, the the sublevel vop ramp doesnt recognize that a new point has been created.
how did you link your top-level ramp settings to the sublevel exactly?
