krakatoa-magma modifier
azin janati
hi every one...I am working on a water modeling and animation.i simulated the water in real flow...i tried to render the real flow particles in krakatoa as the tutorial of thinkbox official web site says(the part about real flow,krakatoa and frost)...i did all the steps but magma modifier just doesnt work correctly...the input of the velocity becomes red as i render the scene and so the render shows nothing.if any one can help me ill be very greatfull...
how does this fit into Houdini/Modeling category?
I think you have better chances on official thinkbox forums
but if you want you can try loading your particles to houdini using realflow plugins and render in mantra :)
You'd have more answers by taking this subject to a place that actually talks about 3ds Max or Krakatoa. http://forums.cgsociety.org/ comes to my mind but I'm pretty sure there are many more forums where you'd receive help on that topic.
On top of that, if you own Krakatoa you can probably email thinkBox about your issue or fill in the form here http://www.thinkboxsoftware.com/support/
This topic is now closed to further replies.
