Exporting attributes to 3DS Max
Akabane
Hey people!
I'm currently using Alembic to go back and forth between Houdini and Max.
I've been trying to figure out how some of the attrs need to be setup so that max can read them.
Already figured out I needed to promote N to vertex (otherwise every loaded frame it tries to reload all normals, fails, etc, sloow - other solution has been turning off import N from max so it rebuilt its own, but it wasn't as desired)
Now the problem I'm facing is how to create material IDs for Max - the geometry that came in, even if it had Material IDs in Max, didn't import any kind of attr in Houdini that could refer to that, so I don't know what it needs, if Primitive, Vertex etc...
Anyone had previous experience and wants to share? :D
Thanks!
  • 9 months later...
I tried a number of different approach with various export formats but none of them doesn't work. Houdini does understand material ID from max via FBX. It recorgnize them as groups which have the names of their material. It doesn't work other way around.
  • 1 month later...
We ran into the same problem yesterday. We needed Material IDs for fractured geometry that needed to be OBJ. Our workaround was to simply offset the UVs for each ID by 1 in U direction.
So matID 1 was 0-1, matID 2 was 1-2 etc. Then in Max we ran a simple script to assign Material IDs based on the mapping position of each face:
 with redraw off
  undo on
  for obj in selection do
   int_uvfaces = polyop.getNumMapFaces obj 1
   for i = 1 to int_uvfaces do
    arr_uvverts = polyop.getMapFace obj 1 i
    pos_vert = polyop.getMapVert obj 1 arr_uvverts[1]
    int_ID = pos_vert[1] as integer + 1
    polyop.setFaceMatID obj i int_ID
   print ( obj.name + " done" )
HouMaxMatIDs.hip
Edited by blackpixel
  • Like 3
  • 1 month later...
Can't tell you how much this helped me out with the same issue.  Thank you.
attachicon.gifHouMaxMatIDs.hip
  • 2 years later...
