Object Merge lots of objects, or something smarter
I've got an animated airplane with hundreds of individual pieces imported through Alembic. How can I merge all off those Shape nodes into soemthing useful I can create a volume with or turn into a phantom object or deform or such things?
I've tried to brute force individual objects into a single object merge before and it poops out at 64 objects (I think). Maybe I should create a new object merge for each Shape node? That sounds emminently scriptable, but I'm at a loss as to where to start.
It seems like a problem that lots of people would have run up against, but I can't seem to find mention of it here or at the sidefx forums.
  • 2 weeks later...
just un-check Build Hierarchy Using Subnetworks on alembic archive node and press Update Hierarchy button
then use the objectmerge with alembicArchivePath/*/* pattern
Cool, thanks! I'll give it a shot.
