Zidhjian Posted April 18, 2013 Share Posted April 18, 2013 Hi Ive tried everything to get a decent fire looking render, and now Ive tried using the smokeless flame, but I don't seem to get a correct render at all. Here is a few pictures to demonstrate the difference between the viewport and the renderer. Also if there is anyone who knows how to get a good starting point in shading realistic fire I would be more than happy to hear your input. Thanks! TESTING.hipnc Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted April 18, 2013 Share Posted April 18, 2013 I experienced a similar issue and just tweaked the default Pyro shader to get what I wanted instead. I saved out my parameters to a preset, hopefully they help. presets.zip Quote Link to comment Share on other sites More sharing options...
Akabane Posted April 18, 2013 Share Posted April 18, 2013 Haven't had a look at your file yet, but it probably it's because when you create a smokeless flame, there's no Density volume. I've been going aroudn this problem just by renaming the temperature field to density, and that's it. Of course modify your shader accordingly to pick up "density" instead of "temperature" in your fire shading tab Quote Link to comment Share on other sites More sharing options...
Zidhjian Posted April 18, 2013 Author Share Posted April 18, 2013 Ok, great to know, i'll check out your preset when I get back home. Thanks! Quote Link to comment Share on other sites More sharing options...
Zidhjian Posted April 19, 2013 Author Share Posted April 19, 2013 I experienced a similar issue and just tweaked the default Pyro shader to get what I wanted instead. I saved out my parameters to a preset, hopefully they help. Btw. how do I open this preset? Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted April 19, 2013 Share Posted April 19, 2013 Btw. how do I open this preset? Drop it in your Houdini $HOME folder, typically in "My Documents" on Windows. On other platforms it's usually called "houdiniXX.X" at the root of the home folder for the user. Quote Link to comment Share on other sites More sharing options...
Nygma Posted April 19, 2013 Share Posted April 19, 2013 This by the way is a specific problem with 12.5. The shader worked perfectly well in 12.1 and below. Seems to have had some changes with it. Quote Link to comment Share on other sites More sharing options...
mawi Posted April 20, 2013 Share Posted April 20, 2013 Isnt this because mantra expects density for the volume quality calculation? If you add and change the new vm_volumequalitychannel to something like temperature it seams to render just fine. Quote Link to comment Share on other sites More sharing options...
venkateshkongathi Posted April 23, 2013 Share Posted April 23, 2013 I have the same problem.I changed the field in pyro shader. Quote Link to comment Share on other sites More sharing options...
Zidhjian Posted April 24, 2013 Author Share Posted April 24, 2013 I don't get it to work, Ive tried everything, changed all the fields in the pyroshader to something else etc. etc. what am I doing wrong? Quote Link to comment Share on other sites More sharing options...
Akabane Posted April 24, 2013 Share Posted April 24, 2013 (edited) You guys, you DON'T have to change the field inside the shader. That DOES NOT WORK. As explained, Mantra expects a density field to make the pyro shader work. If your sim doesn't have that, no render - simple. You have 2 options for now: 1- What Mawi has suggested. Dive inside the shader and change the parameter that the renderer expects to calculate quality (<-cleaner technique, thanks!) or 2- My solution which is just rename the temperature field to be the density field. If you go with (2), you don't do this change in the shader. What you've basically done was trying to tell the shader to evaluate the fire/density using different fields. That's just how it will look.You'll need to go in your SOP object with the sim, drop a "name" node, and rename "temperature" (or heat or whatever) to "density". Now use "density" in your shader for the fire field. Edited April 24, 2013 by Akabane Quote Link to comment Share on other sites More sharing options...
mawi Posted April 24, 2013 Share Posted April 24, 2013 (edited) 1- What Mawi has suggested. Dive inside the shader and change the parameter that the renderer expects to calculate quality (<-cleaner technique, thanks!) Well my suggestion was to add the mantra attribute vm_volumequalitychannel on the mantra node (or the object node?) and set it to the field you use as fire density. However someone more involved in rendering will have to fill in if this is a valid solution... Volume quality channel parameter allows you to cull empty volumes based on a field other than density. Edited April 24, 2013 by mawi Quote Link to comment Share on other sites More sharing options...
Zidhjian Posted April 25, 2013 Author Share Posted April 25, 2013 Hmmm... And where can I find this vm_volumequalitychannel? And where do I change the fields in the shader? You mean in the tab fire->density and change the field temperature to density? That doesn't work for me at least. Quote Link to comment Share on other sites More sharing options...
Zidhjian Posted April 25, 2013 Author Share Posted April 25, 2013 I also discovered when unchecking a field in the import_pyrofields node I also get something different. Quote Link to comment Share on other sites More sharing options...
Zidhjian Posted April 25, 2013 Author Share Posted April 25, 2013 As you can see here. Quote Link to comment Share on other sites More sharing options...
Sapam Posted May 16, 2013 Share Posted May 16, 2013 (edited) I got the smokeless flame working somehow and here is how i did it. 1) In the Fluid Source node I added another volume called "density" 2) In ImportPyroBuild turn on Import Option for Density. 3) In Import Pyro Build I added a VolumeVOP after the DOP I/O 4) In the Volume VOP I added the Temperature to the Density (density was Zero). Wanted to assign temp value to Density. Instead of Add you can use Mix with bias 1. 5) Lastly in the Pyro Shader under Smoke > Density set: Field Name = density Under FieldShapeTab set Target Range to 0 to 0 I have provided snapshot of all the 5 Steps below: Edited May 16, 2013 by Sapam Quote Link to comment Share on other sites More sharing options...
anim Posted May 16, 2013 Share Posted May 16, 2013 as it was mentioned just add Volume Quality Channel rendering parameter to your material or object and set it to heat or temperature instead of non-existent density, no alterations necessary or as Zidhjian mentioned uncheck import of fuel volume as that seems to be used to cull volumes because density is not present, if you not import it other channel will be used Quote Link to comment Share on other sites More sharing options...
Sapam Posted May 16, 2013 Share Posted May 16, 2013 Unchecking Fuel Works. I was wondering which field Zidhjian unchecked, as he didn't mentioned that. Thanks for the Info. Thanks, Quote Link to comment Share on other sites More sharing options...
acti Posted May 21, 2013 Share Posted May 21, 2013 delete the fuel field and it will render correctly. Quote Link to comment Share on other sites More sharing options...
