mrWolf Posted May 1, 2013 Share Posted May 1, 2013 (edited) I am sorry to bring back this zombie question about this topic again I probably read all the posts on internet about the topic and the houdini doc as well, but I am now more confused than before Question A) What I'd like to do is to configure my houdini system path variables in order to follow this priority for OTL scan and scripts too (like 123 ... 456 ... etc): 1) a shot example: d:/projects/supercoolproj/seq1/shot3/otls d:/projects/supercoolproj/seq1/shot3/scripts ... 2) a sequence example: d:/projects/supercoolproj/seq1/otls d:/projects/supercoolproj/seq1/scripts ... 3) a show example: d:/projects/supercoolproj/otls d:/projects/supercoolproj/scripts ... 4) houdini $HOME/houdini12.5/otls $HOME/houdini12.5/scripts $HOME/houdini12.5/.. ... Basically the deeper the directory structure, the higher the override priority with elements with the same file name. Now, so far only the 4) works. My current status is the following: ... I copied and pasted the directories created by houdini at install time in d:/data/Houdini/prefs/houdini12.1 d:/data/Houdini/prefs/houdini12.5 ... and created a system variable HOME pointing to d:/data/Houdini/prefs So far, Houdini can find all the otls i store in $HOME/houdiniXX.X/otls Can someone help me to setup $HOME/houdini12.5/houdini.env to follow the priorities illustrated at the beginning of the message or point me to some documentation that clearly explains it ? p.s. I am on Windows 8 thank you in advance for any possible help on this Edited May 1, 2013 by mrWolf Quote Link to comment Share on other sites More sharing options...
mrWolf Posted May 1, 2013 Author Share Posted May 1, 2013 Update : I managed to understand how it works modifying the file houdini.env JOB="C:/data/HOUDINI/projects" HOUDINI_OTLSCAN_PATH="$JOB/otls;@/otls" Now I would like to update the otl scan path accordingly to the hip file i am loading into houdini (variable $HIP) following a certain directory structure for the project i am working on. I tried to include it here HOUDINI_OTLSCAN_PATH="$HIP/otls;$JOB/otls;@/otls" But obviously houdini doesn't know how to expand $HIP before actually opening a hip file, so the path ends up wrong >>> os.environ["HOUDINI_OTLSCAN_PATH"] '/otls;C:/data/HOUDINI/projects/otls;@/otls' Is there a way to force an update and refresh of the otl scan path every time a new hip file is loaded ? I prefer not to execute some python script outside of Houdini in order to set the project (changing some global variable) and then launch houdini, if possible. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted May 1, 2013 Share Posted May 1, 2013 If you want different OTL files per scene that you open just store the OTL within the scene file (an option when you save). Otherwise the best option would be to set the environment variable prior to opening Houdini. Many pipelines will set environment variables before opening an application with specifics like the sequence, shot, and so forth to manage where other files like caches and renders go so it would make sense to handle the OTL path the same way (unless there's no pipeline established). There might be a way to do what you want, maybe check with SESI support? Quote Link to comment Share on other sites More sharing options...
mrWolf Posted May 1, 2013 Author Share Posted May 1, 2013 Luke, yes I've been using that approach in many studios. It's a good one since it makes the whole pipeline aware about the job environment , not only houdini and many other reasons of course. I am just trying to understand how the wheel works and maybe reinvent it a little bit, as usual eheh And here it comes another question: I am aware that I can access and modify a 'shell' houdini variable using os.envir[<variable>"]=... But i noticed that this deals with the variables at os level. So, for instance, variables like $HIP are not updated in real time in this environment when you load a new hip file. hou.expandString(<variable>) ... works great in terms or retrieving $HIP in real time. But I didn't find a way to write into an environment variable (for instance "HOUDINI_OTLSCAN_PATH") and make the current houdini session aware of this change. Quote Link to comment Share on other sites More sharing options...
lukeiamyourfather Posted May 1, 2013 Share Posted May 1, 2013 But I didn't find a way to write into an environment variable (for instance "HOUDINI_OTLSCAN_PATH") and make the current houdini session aware of this change. Well, that's not really how it works at least from the shell and process perspective. It would need to be set prior to launching the process, hence outside of Houdini. The Houdini way to change a variable after loading would be through the "Aliases and Variables" interface from the Edit menu. Those can be changed or listed with the Hscript command "set" but I'm not sure if it has a Python equivalent yet (could run Hscript commands from Python using hou.hscript). Quote Link to comment Share on other sites More sharing options...
edward Posted May 2, 2013 Share Posted May 2, 2013 But obviously houdini doesn't know how to expand $HIP before actually opening a hip file, so the path ends up wrong If you bring up a Houdini Command Line Tools shell, and run "hconfig -ap", you get this help at the top Special characters in path definition are: @ - Typically expands to the HOUDINI_PATH. Thus, if the HOUDINI_PATH was set to: $HIP $HFS/houdini $HOME/houdini a path defined as "@/vex" would expand to the paths $HIP/vex $HFS/houdini/vex $HOME/houdini/vex = - This expands to the $HIP variable. This path will always point to where the currently loaded hip resides. & - The ampersand character expands to the "default" path. For example, to add a directory to the a path without worrying about what the default path should actually be, simply set the path to: "/mypath;&". This will search the "/mypath" path first, then search the default path. ^ - Some paths are used for multiple directories. For example, the HOUDINI_VEX_PATH is used to define the search path for Surface, Displacement, Sop, etc. VEX shaders. For VEX, the ^ symbol expands to the shader type. Thus, if the HOUDINI_VEX_PATH variable is set to something like "/usr/local/vex;$HOME/vex/^", when loading Surface shaders, the following directories will be scanned: /usr/local/vex $HOME/vex/Surface and if Sop shaders are being searched for, the following paths will be searched: /usr/local/vex Summary: Use = Quote Link to comment Share on other sites More sharing options...
mrWolf Posted May 2, 2013 Author Share Posted May 2, 2013 @luke After reading a bit more the documentation and other forum posts, I realized what you mean with that. I was searching a way to refresh houdini otl path on the fly during an houdini session. I understand it's not particularly healthy or useful other than indulging the joy of finding a hack Closing houdini, changing the job enviromnent with a script and relauching houdini is historically and for good reasons the best way to go for sure, I agree with you. @edward Man it works great ! Thank you so much So, to sum, in my environ.env file I have the following now: JOB="C:/data/HOUDINI/projects" HOUDINI_OTLSCAN_PATH="=/otls;$JOB/otls;@/otls" So now the otls are scanned with this priority: 1 - $HIP/otls 2 - $JOB/otls 3 - whatever else/otls I created a shelf tool with the following script that insures that the new otl scan path is updated with the current hip file (it basically removes otls that disappear from the path, and loads new otls): hou.hscript("otrefresh -r") for f in hou.hda.loadedFiles(): hou.hda.reloadFile(f) note: in the documentation it's written that otrefresh is now obsolete and we should use hou.hda.reloadFile() hou.hda.loadedFiles() After a couple of tests I realized that this is true if we remain in the same domain of files and paths already in use. If $HIP changes, then 'otrefresh -r' is still needed to update otl scan path but alone won't be enough to get rid of old paths or otls that are not anymore in the newly refreshed otl scan path. That's why I had to put both in the shelf tool. Thank you a lot for your help Luke and Edward ! Quote Link to comment Share on other sites More sharing options...
