delete points on curve except first and last
I think there are many ways to do this. I would use this pattern:
0 $N
and set it to "Delete Non-Selected".
Mmm, maybe I didn't state it correctly. I don' t want to delete all points between first and last, only a percentage based on the pattern !*:10
try this as a python expression in the pattern field
inc = 10
points2delete = range(1,len(hou.pwd().inputs()[0].geometry().points())-1,inc)
return points2delete
[/CODE]
It gives me an error :
Error: Unable to evaluate expression (Syntax error - extra tokens detected in expression (/obj/curve_object1/Br1_fence1/delete1/pattern)).
My bad, it was not correctly set to python. Seems to work now :)
Edited by br1
