How to make a Realistic Scattered Water Drops?
2024429207.jpgcocacola_1-zaayoo.jpg?type=w3
hi i want to make water drops like this.
all i know is scatter a point and use a copy node to add metaball
or particle fluid surface
and use a vopsop to deform the drops randomly.
but all shapes are same. i want to make each drop different.
here is my hip file. any comment is good for me:)
scattered_meta_1.hip
Edited by daehuck
I scatterd more points randomly around your MainPoints, with the help of attribute transfer.
Attached the hip, hope it goes in your desired direction.
Cheers Martin
this can be a one of solution thanks very much:)
is there other solution to deform the each water drops, per one PT?
Any way, thanks again!
Edited by daehuck
You could try to Stamp a random value based on template $PT if you are using the Copy SOP.
you can use vopsop after copying to randomize the points that are touching the ground.
omg thank you very much!
I think this is the ideal shape!!!
Can i get a some information of this node?
I've never seen a vdb node.
Edited by daehuck
no problem, I'm not the best person to explain VDB inside houdini, but VDB's are volumes (opensource). new in 12.5 I believe. You can read more about them here http://www.openvdb.org/
or hopefully someone more knowledgeable than I can chime in.
thanks!!
I have to study about VDB
I feel this node is very important widely.
Edited by daehuck
