houdini1987 Posted July 31, 2013 Share Posted July 31, 2013 Posted: Wed Jul 31, 2013 1:59 pm Post subject: fire ember particles Hi, I am trying to create fire embers similar to this picture. I created the random flying particles through popnet. I dont know how to get the glowing embers on the particles. Thanks in advance Quote Link to comment Share on other sites More sharing options...
Skybar Posted July 31, 2013 Share Posted July 31, 2013 Posted: Wed Jul 31, 2013 1:59 pm Post subject: fire ember particles Hi, I am trying to create fire embers similar to this picture. I created the random flying particles through popnet. I dont know how to get the glowing embers on the particles. Thanks in advance I don't have an answer for you, but lol. Copy pasting taken to a whole new level! Quote Link to comment Share on other sites More sharing options...
Fabiano Berlim Posted July 31, 2013 Share Posted July 31, 2013 It's possible to simulate glow in particle render, but 99% of the time it's done in comp. Faster and easy to change. But what I think you're asking is not glow, is motion blur. 2 Quote Link to comment Share on other sites More sharing options...
pclaes Posted August 1, 2013 Share Posted August 1, 2013 If you want good embers, you copy flakes onto the particles. -- You design a flake by making a tiny low resolution grid with some noise. -- this setup is more for close-mid ground. For background use pure particles. You can use instancing if you want. You can control their rotation with an orient quaternion. You add a shader to light up the edges or the inside, you can give them superbright (higher than 1) values so they don't fade when blurred. Curl noise is your friend, as well as adding a bit of noise (small amplitude) per particle (offset by ID). If you want good sparks (which look like curved motion trails), you should turn your particles into short nurbs curves and carve them & shade them along the uv. 7 Quote Link to comment Share on other sites More sharing options...
Mayankesh Posted August 1, 2013 Share Posted August 1, 2013 (edited) having similar issues :/ Edited August 1, 2013 by mayankeshranjan Quote Link to comment Share on other sites More sharing options...
houdini1987 Posted August 1, 2013 Author Share Posted August 1, 2013 If you want good embers, you copy flakes onto the particles. -- You design a flake by making a tiny low resolution grid with some noise. -- this setup is more for close-mid ground. For background use pure particles. You can use instancing if you want. You can control their rotation with an orient quaternion. You add a shader to light up the edges or the inside, you can give them superbright (higher than 1) values so they don't fade when blurred. Curl noise is your friend, as well as adding a bit of noise (small amplitude) per particle (offset by ID). If you want good sparks (which look like curved motion trails), you should turn your particles into short nurbs curves and carve them & shade them along the uv. Thanks Peter, A simple scene file will be of great help. My shader knowledge is very limited as i am new to it. I tried putting constant shader on particles as there will be lot of motion blur and details wont be visible. But i think i am not getting the satisfactory result. Quote Link to comment Share on other sites More sharing options...
