Close a curve without "creating" a renderable surface
dpap
Is there a simple way of closing an open curve with out creating a renderable/visible surface. After closing the ends I just want  to get a simple like the circle on the right.
The Ends Sop creates a surface..How can I avoid this? Is placing the first and last points at the same position the only solution?
Btw the curve is animated and random pointnum sorting.
Can I somehow get for every frame the pointnum of my first and  last point so I can push them in the same position?
Super !!! Thank  you Anim!!! Your magic always works! :)
Can an admin please clean up the mesh I did with posting accidentaly the same thing 1000 times???
I swear it wasn't my fault!!!  :unsure:
 nevermind ..admins are propably fasters than my typing speed!
Edited by dpap
