managing objects in a scene
Hi all
Im wondering how you all go about managing the objects in a scene. Is it just a matter of making many different scenes and compositing? This is something I don't do much of - but definitely should for aesthetic reasons if nothing else, i.e. render passes.
buy a better computer isnt an option just yet :D but im thinking this problem must scale to very heavy scenes even on top hardware? i mean i doubt all of new york was one scene on one computer in spiderman...
similarly, with a fairly complex model, different parts of it have different subdivision levels, either none, 1 or 2. it would be ideal to have a global subdiv ON/subdiv OFF toggle, so i can quickly drop/raise the scene poly count, rather than going through the network and turning on/off all the different subdiv OPS, which each take time to cook - generally that's a pain.
maybe each object should have just a couple of subdiv OPS and pipe all geometry into a merge then into that one subdiv. it seems to make sense to keep the parts seperate and finally into a merge, but i could be wrong.
any ideas appreciated! :)
I'd consider using a Houdini variable. $SUBDIV_LEVEL or something. You can easily also add aliases to increasing and decreasing this too.
In the Textport:
Director ->  alias low   set subdiv=0
Director ->  alias med   set subdiv=1
Director ->  alias high   set subdiv=2
Director ->  med
Director ->  echo $subdiv
1
Director ->  high
2
Hope this helps,
Jason
No need to code anything- just add a custom variable in the Settings -> Aliases and Variables -> Variables window and it will be there whenever you open the scene.
At the two blank areas at the bottom type in something like "SubDepth" and "1" (without the quotes).
Now in all your Subdivide SOPs put $SubDepth in the "Depth" field. Now you can go to that Aliases and Variables window and change SubDepth to 0 for no effect or 2 or 3 or whatever and it will get changed everywhere at once.
Doesn't everyone create their own variables like this?!? ;)
-Craig :)
Here's another thing you might consider.
Start by saving the geometry in your scene as .bgeos.
Now that you have written the geos out you can replace
the objects in your scene with proxy/bounding objects.
this should speed things up.
Obviously you don't want to render the proxy geo so here's
what you do:
go to your Geomerty nodes and change the Geometry parmeter to
"bounded file (render SOP defines bounds)"
You'll notice that the parameter "Geometry File" parameter
is now avaiable. point this parameter to the bgeo you saved to
disk.
When you render, it should render the geomerty you saved to file.
In addition it will only load the geo into ram if it's in the
camera frustum, and only for the bucket that's being rendered.
All the Best
Luca
wow i didnt know any of this was even possible.. thanks all for your ideas i need to wait until i get home to test them but i am seriously impressed.
houdini ROCKS (yeah yeah you know that already :lol:)
cheers :)
will summarise it all into the wiki when i have it working!
  • 11 months later...
or just have two branched nulls at the bottom of your sop chains:
         last SOP
  null_01      subdivide
                  null_02
where null_01 has the display flag and null_02 has the render flag
that way you can view low res stuff in the viewport but when you render you'll get the subdivided geometry...
going along with jason's and craig's post way back, what i like to do is create aliases/variables and attach them to my F keys on the keyboard... just set your alias for "low" to F9 and "high" to F10 and that should be it. just switch between with a touch at the keyboard. i do this for toggling display flags on multiple obj groups as well.
hehe 2 more ways of doing it thats what i like to see.
some wierd firefox bug only showed the first 4 posts in this thread so a bit of an unecessary bump but if it helps someone else with a houdini Eureka! moment like i just had thats good :lol:
Absolutely :)
My example is also meant to demonstrate some use for the "alias" command - you might need to set several variables to various values or run other commands. "Alias" can help you not have to remember all the settings for these.
