Fluid emission from shader attribute
merlino
Hi, I'm kind of stuck trying to emit fluid from a shader attribute.
The problem is that I have a ramp material and I would like to emit fluid only from the opaque part, not the transparent one.
I found some help but reading a texture, not a shader. How can I do that?
Wouldn't it be easier to do it the other way around? Create an attribute on your geo that you both emit from and control your opacity with.
Hi David, the problem is that I use the ramp shader witch works with the facing ratio and I don't know how to store that info to the points ...
Maybe the solution is in what Jason says, even if I don't know how to reach it right now ... tomorrow I'll do some test :)
Many thanks!
