jwhit6142004 Posted December 28, 2013 Share Posted December 28, 2013 I am just wondering why the smoke is so thick compared to the viewport after I've done the transfer under the utilities tab in the pyro shader. Correct me if im wrong but isn't the whole point of hitting the transfer button that the shader takes on what you see in the viewport? Here is a screenshot to show you what i mean and also the HIP file. 12_27_13_HIGHRES_ShockwaveV1.hipnc Quote Link to comment Share on other sites More sharing options...
Skybar Posted December 28, 2013 Share Posted December 28, 2013 If you keep both the render and viewport gamma corrected they should look alike. Go to the topmenu, Edit -> Color Settings -> Color Correction -> set the gamma to 2.2, and tick all the boxes (or those that you want) -> hit Apply, and you might as well hit Save As Default too. I changed nothing in your hip and it looks like this for me, viewport to the left and render to the right: Quote Link to comment Share on other sites More sharing options...
jwhit6142004 Posted December 29, 2013 Author Share Posted December 29, 2013 hmm... thats weird. I did exactly what you told me and im still getting the same original results. So alls you did was adjust those settings that you spelled out and then hit render and it worked? Do you think it could be something on my computer and not the program at all? Quote Link to comment Share on other sites More sharing options...
Skybar Posted December 29, 2013 Share Posted December 29, 2013 That's all I did, yes. Does anything in the viewport change at all if you change the gamma in color settings? Quote Link to comment Share on other sites More sharing options...
jwhit6142004 Posted December 29, 2013 Author Share Posted December 29, 2013 yea it does make it lighter in the viewport. But then it seems to just make the smoke that much more thicker... Am i suppose to redo the transfer in the shader after ive changed those settings or should it automatically update. Also here is some pictures and the hip file again. 12_27_13_HIGHRES_ShockwaveV1.hipnc Quote Link to comment Share on other sites More sharing options...
Skybar Posted December 29, 2013 Share Posted December 29, 2013 You shouldn't have to change anything else, and your render there looks crazy - did that happen when you only changed the gamma? That shouldn't happen. Which Scene Renderer (edit -> preferences -> 3d viewports) are you using? The gamma doesn't seem to have any effect on GL 1.1, so use 2 or 3. You could also update your graphics driver if you got an old one. Your hip still works fine here as well, so it could be something specific to your computer. I have no ideas left though with what could be wrong. Anyone else? Quote Link to comment Share on other sites More sharing options...
jwhit6142004 Posted December 30, 2013 Author Share Posted December 30, 2013 Here is the settings when i went to Edit > Preferences > 3D Viewport Quote Link to comment Share on other sites More sharing options...
wildon Posted January 7, 2014 Share Posted January 7, 2014 you find any solution? i think a have a same problem... Quote Link to comment Share on other sites More sharing options...
Guest tar Posted January 7, 2014 Share Posted January 7, 2014 (edited) Are you running AMD graphics cards? High Quality transparency is disable because of a bug. http://www.sidefx.com/docs/houdini13.0/news/13/misc edit: just tested. probably not that AMD. looks fine on OsX 10.9, GL2, AMD7950, H13.0.283 Edited January 7, 2014 by tar Quote Link to comment Share on other sites More sharing options...
jasonj3d Posted February 10, 2014 Share Posted February 10, 2014 Hi, Has anyone found a solution? I am also having this problem. Thanks! Quote Link to comment Share on other sites More sharing options...
jwhit6142004 Posted February 11, 2014 Author Share Posted February 11, 2014 No, i just resorted to editing the shader myself. And no I have a NVIDIA GeForce 9400 card Quote Link to comment Share on other sites More sharing options...
Guest tar Posted February 11, 2014 Share Posted February 11, 2014 Have you set the Gamma in Color Settings/Color Correction to 1 and the Gamma in Mplay to 1? Please have a look at the screen grabs for the variety of combinations - this is from Houdini 12.5 Both match dark Color Correction Gamma = 1 Mplay Gamma = 1 Both match light Color Correction Gamma = 2.2 Mplay Gamma = 2.2 Mismatch Color Correction Gamma = 1 Mplay Gamma = 2.2 Quote Link to comment Share on other sites More sharing options...
jasonj3d Posted February 11, 2014 Share Posted February 11, 2014 Hey Marty, So when I change the gamma in the color settings for the viewport it does nothing. I can put it to any number and the view remains the same. The render view responds correctly, but the gl view does not. Even if I set it to 2.2, it still shows it as if it was set to 1. -Jason Quote Link to comment Share on other sites More sharing options...
Guest tar Posted February 11, 2014 Share Posted February 11, 2014 Try these two things before declaring a bug candidate; 1.Display Option/Viewport tab. Under Color Correction set the Gamma there to something. It should update the viewport immediately when you press enter (tested on osX, H 13.0.317) 2. Under Color Settings/Color Correction make sure once you change the Gamma value to click Apply button. Quote Link to comment Share on other sites More sharing options...
jasonj3d Posted February 11, 2014 Share Posted February 11, 2014 Try these two things before declaring a bug candidate; 1.Display Option/Viewport tab. Under Color Correction set the Gamma there to something. It should update the viewport immediately when you press enter (tested on osX, H 13.0.317) 2. Under Color Settings/Color Correction make sure once you change the Gamma value to click Apply button. Unfortunately, neither of these work. #1 does nothing at all and #2 only affects the render view, but the gl scene view doesn't change. Scene view always shows in gamma 1. thanks, -Jason Quote Link to comment Share on other sites More sharing options...
Guest tar Posted February 11, 2014 Share Posted February 11, 2014 (edited) Send a bug report in to Sesi. It works with no effort here and should 'just work' http://www.sidefx.com/index.php?option=com_content&task=view&id=768&Itemid=239 Also make sure that your video drivers are up to date. Edit: Make sure to include the operating system, maybe some screen grabs showing the lack of effect i.e. with gamma 1 and gamma 2.2, the version of Houdini, video card model and driver number. Edited February 11, 2014 by tar Quote Link to comment Share on other sites More sharing options...
jasonj3d Posted February 11, 2014 Share Posted February 11, 2014 Sounds good. Thanks, Jason Quote Link to comment Share on other sites More sharing options...
