idini Posted August 19, 2002 Share Posted August 19, 2002 Hi, I am just getting started with Houdini and am having some display problems with a GeForce 4 card. The image below shows this better than I could describe it. Has anybody else had a similar problem and, if so, is there a fix? I have installed the latest display drivers, etc. Thanks, Dave Carroll Quote Link to comment Share on other sites More sharing options...
danteA Posted August 19, 2002 Share Posted August 19, 2002 Are you displaying a Wireframe over Smooth Shaded view there? You might want to try setting the environment variable HOUDINI_DISABLE_DISPLAYLIST to have a value of 1 and see if that works around the driver problem. Which driver version are you running exactly btw? Are you on Linux or Windows? Quote Link to comment Share on other sites More sharing options...
idini Posted August 19, 2002 Author Share Posted August 19, 2002 Thanks for the reply. It is wire over flatshaded but I get the same with smoothshaded. The wireframe only display appears fine though. I am using the Detonator 30.82 drivers on Windows 2000 sp2. I will try setting the variable as suggested when I get home tonight. I had tried altering all the OGL variables but to no avail. Didn't try the one you mention though. Fingers crossed! Thanks again, Dave Carroll Quote Link to comment Share on other sites More sharing options...
Jason Posted October 7, 2002 Share Posted October 7, 2002 If you hit "d" and go to the Display parameters, there is a field for Hidden Line Sensitivity. Wiggle that: if might help! Ciao! J Quote Link to comment Share on other sites More sharing options...
mike Posted October 7, 2002 Share Posted October 7, 2002 Another option is, to set the nearclip > 1 Quote Link to comment Share on other sites More sharing options...
will Posted December 7, 2002 Share Posted December 7, 2002 i was having similar problems seeing artifacts, see-through faces, and a jumble of jaggedies. changing the near clip plane from the default .001 to .1 completely solved it. thank you many times for the great suggestion mike! Quote Link to comment Share on other sites More sharing options...
