Wolfwood Posted June 20, 2004 Share Posted June 20, 2004 Quick question for yall. I had a ton of curves that I wanted to make a surface out of. I knew I could do it I just couldn't remember the name of the SOP that did it. So I proceeded to look for 15 minutes until I finally found the Skin SOP. The thing is....this ALWAYS happens, I always forget the name of the Skin SOP. It generally goes something like this.... (once a month on average) Is it the sweep....nope....er.... loft? nope no loft sop not the extrude.... hmmm....what the....nope..... I know it starts with a "S"...... let me try sweep again....no..still doesn't work.... Stitch?....nope... SKIN!!!! SKIN SOP! Anyway.... do you guys/gal have op that you always forget the name to? Quote Link to comment Share on other sites More sharing options...
renderpipe Posted June 20, 2004 Share Posted June 20, 2004 I forget about the skin sop as well but i'm new I was trying to loft some curves and was getting fustrated because there is no "loft" SOP. After about 20-30 min of trying many SOPs, skin was the one. It would be great once we can search the online docs and type in a keyword for lofting surfaces. Then we won't need to remember the sop name only the description. Quote Link to comment Share on other sites More sharing options...
Mcronin Posted June 20, 2004 Share Posted June 20, 2004 AddAttibute VOP. Every once in a while I try to do a Geometry VOP and I'm like "OK, wtf is the name of that VOP to bring in an attribute?" I keep wanting to use the Parameter VOP. Someone at work actually reported it as a bug to SESI because I told him I couldn't find the "Import Attribute VOP" and he thought maybe it had not made it into the update. Even now I had to actually go into VOPs to find the correct OP name for this post. Quote Link to comment Share on other sites More sharing options...
Marc Posted June 20, 2004 Share Posted June 20, 2004 Yeah I always confuse the transform SOP. It's listed as transform in the lister, but gets plopped down as xform... So whenever I'm not thinking straight I start in the 'x' section and get totally lost from there. Marc Quote Link to comment Share on other sites More sharing options...
FrankFirsching Posted June 21, 2004 Share Posted June 21, 2004 Yes, there is a SOP I forget the name of everytime,..... But I can't remember which one it was .... Oh, wait! I think it was the Sweep-SOP. Quote Link to comment Share on other sites More sharing options...
