mrWolf Posted January 22, 2014 Share Posted January 22, 2014 (edited) I am struggling a bit trying to get this simple thing working (I am on H13): I want to examine the 3 closest points surrounding each point in a point cloud, and simply print some debug message. This is the code I use in an Attrib Wrangle sop node: int handle=pcopen(@OpInput2,"P",@P,10,3); printf("ptnum %d\n",@ptnum); int iteration=0; while (pciterate(handle)) { iteration++; printf("iteration %d\n",iteration); } pcclose(handle); I have 10 points scattered and I use them as input 1 and 2 for the Attrib Wrangle node. So I am trying to loop through the points in the input 1, and for each one of them open a pc based on the input 2. I expect a feed back like this : ptnum 0 iteration 1 iteration 2 iteration 3 ptnum 1 iteration 1 iteration 2 iteration 3 ... ptnum 9 iteration 1 iteration 2 iteration 3 But I receive this feedback instead: ptnum 0 ptnum 1 ptnum 2 ptnum 3 ptnum 4 ptnum 5 ptnum 6 ptnum 7 ptnum 8 ptnum 9 iteration 1 iteration 2 iteration 3 I must clearly be doing something conceptually wrong. I thought that the content of a Attrib Wrangle node set to "point" was looping through all the points in the first input. So the code should be executed on all the points , is that correct ? (scene file included) pciterate_test.hipnc Edited January 22, 2014 by mrWolf Quote Link to comment Share on other sites More sharing options...
mrWolf Posted January 22, 2014 Author Share Posted January 22, 2014 more confusion: if I simply change the printf statement inside the loop to printf("pt %d - iter %d\n",@ptnum,iteration); Then the feedback is as follows: ptnum 0 ptnum 1 ptnum 2 ptnum 3 ptnum 4 ptnum 5 ptnum 6 ptnum 7 ptnum 8 ptnum 9 pt 0 - iter 1 pt 1 - iter 1 pt 2 - iter 1 pt 3 - iter 1 pt 4 - iter 1 pt 5 - iter 1 pt 6 - iter 1 pt 7 - iter 1 pt 8 - iter 1 pt 9 - iter 1 pt 0 - iter 2 pt 1 - iter 2 pt 2 - iter 2 pt 3 - iter 2 pt 4 - iter 2 pt 5 - iter 2 pt 6 - iter 2 pt 7 - iter 2 pt 8 - iter 2 pt 9 - iter 2 pt 0 - iter 3 pt 1 - iter 3 pt 2 - iter 3 pt 3 - iter 3 pt 4 - iter 3 pt 5 - iter 3 pt 6 - iter 3 pt 7 - iter 3 pt 8 - iter 3 pt 9 - iter 3 I really need some clarification here, helpp Quote Link to comment Share on other sites More sharing options...
anim Posted January 22, 2014 Share Posted January 22, 2014 it just looks like that if the print result is the same for all points it prints it just once, otherwise per each point but even if it print's it once it will compute the values per each point so don't worry, your code is correct PS:if you need the iteration number you can directly use for loop instead of while loop as you would get that for free Quote Link to comment Share on other sites More sharing options...
mrWolf Posted January 22, 2014 Author Share Posted January 22, 2014 yes it's weird, I just realized the code works as you say. The fact the print vex command doesn't work properly is a bit of a bummer cause it's really useful to have that kind of debug feedback but I guess SIMD architecture is not precisely printf friendly. it just looks like that if the print result is the same for all points it prints it just once, otherwise per each point but even if it print's it once it will compute the values per each point so don't worry, your code is correct PS:if you need the iteration number you can directly use for loop instead of while loop as you would get that for free Quote Link to comment Share on other sites More sharing options...
mrWolf Posted January 22, 2014 Author Share Posted January 22, 2014 (edited) I did some additional test. I was curious to see the difference in performance between Point Wrangle Attrib Wrangle VOP SOP So I scattered 2 million points and for each point I calculated the number of neightbors (max 100) in a radius of .2 units (scene included). It seems there is a significant difference in speed : VOP SOP is still way faster. Kinda disappointing cause I really was looking forward dropping VOPs in favour of VEX code. EDIT I was totally wrong: i was calculating the vop sop on 20 points instead of 100. That's why it was faster ! eheh apologies. Edited January 22, 2014 by mrWolf Quote Link to comment Share on other sites More sharing options...
anim Posted January 22, 2014 Share Posted January 22, 2014 (edited) whether it is Point Wrangle, Attrib Wrangle, VOP SOP or AttribVOP SOP, they all result in compiled VEX code so it shouldn't really matter which one you use performance wise of course there may be little differences between (Point Wrangle/VOP SOP) vs (Attrib Wrangle/AttribVOP SOP) as the later 2 are CVEX based, but that may be as well irrelevant the difference in your scene is simply based on the fact that for Point and Attrib Wrangle you use 100 point lookup and for VOP SOP only 20 and remember that Point Wrangle is in essence just an nicely wrapped VOP SOP so it wouldn't make sense for VOP SOP to be faster than VOP SOP especially if you know that even VOP network is at the end just a VEX code so now you can happily use Wrangle nodes EDIT: and that print thing I wouldn't be seeing as a bad thing as it's pretty clever optimization, simply if you want to force different output per point, include ptnum as a part of the print output, because otherwise you wouldn't know which point produced that output anyway, you will just end up with millions of prints of the same value or something, not useful at all in my opinion Edited January 22, 2014 by anim Quote Link to comment Share on other sites More sharing options...
mrWolf Posted January 22, 2014 Author Share Posted January 22, 2014 Yes you're right, It all makes sense, even the printf matter actually. Very much appreciated Thomas. whether it is Point Wrangle, Attrib Wrangle, VOP SOP or AttribVOP SOP, they all result in compiled VEX code so it shouldn't really matter which one you use performance wise of course there may be little differences between (Point Wrangle/VOP SOP) vs (Attrib Wrangle/AttribVOP SOP) as the later 2 are CVEX based, but that may be as well irrelevant the difference in your scene is simply based on the fact that for Point and Attrib Wrangle you use 100 point lookup and for VOP SOP only 20 and remember that Point Wrangle is in essence just an nicely wrapped VOP SOP so it wouldn't make sense for VOP SOP to be faster than VOP SOP especially if you know that even VOP network is at the end just a VEX code so now you can happily use Wrangle nodes EDIT: and that print thing I wouldn't be seeing as a bad thing as it's pretty clever optimization, simply if you want to force different output per point, include ptnum as a part of the print output, because otherwise you wouldn't know which point produced that output anyway, you will just end up with millions of prints of the same value or something, not useful at all in my opinion Quote Link to comment Share on other sites More sharing options...
magneto Posted January 23, 2014 Share Posted January 23, 2014 I think printf behaves that way because the order of execution is not determined. So you have no control over which point executes first, or second, etc. Quote Link to comment Share on other sites More sharing options...
mrWolf Posted January 23, 2014 Author Share Posted January 23, 2014 Yeah , the non sequential order must be related to the simd architecture. What I don't quite understand is why it prints out all the steps (even though not in a sequential order) only when the content of the string differs from a previous string (regardless of the semantic of the code, which is just an example of course). It would be interesting to know how this internally works, just for the sake of curiosity. I think printf behaves that way because the order of execution is not determined. So you have no control over which point executes first, or second, etc. Quote Link to comment Share on other sites More sharing options...
Green-Man Posted January 23, 2014 Share Posted January 23, 2014 Try to execute this example with multithreading turned off ("Use Max Processors" on the Mantra ROP). Would the output be more predictable? Quote Link to comment Share on other sites More sharing options...
mrWolf Posted January 23, 2014 Author Share Posted January 23, 2014 I am not sure I know how to use a Mantra Rop to force the execution of a sop node. Can you elaborate ? Try to execute this example with multithreading turned off ("Use Max Processors" on the Mantra ROP). Would the output be more predictable? Quote Link to comment Share on other sites More sharing options...
anim Posted January 23, 2014 Share Posted January 23, 2014 yes, the order of printf is related to SIMD fashion which means that each instruction is executed for all points before next one so the first print for all points, then the next one for all points etc it doesn't need to be running on multiple CPUs so you'll always get this behaviour multithreading works on batches per 256(or so) elements so with lower point count is one CPU anyway so in conclusion to my understanding with multithreading off: all points are executed in order one instruction at a time with multithreading on: individual batches of 256 points are executed one instruction at a time with no predictable order in which each batch finishes if you wanted one point at a time with all instructions just run Attrib VOP /Attrib Wrangle in Detail mode and loop for all points so after knowing all this there should be no surprise in order of printf outputs, except for that unexpected optimisation when all points return the same value as one entry Quote Link to comment Share on other sites More sharing options...
