magneto Posted January 30, 2014 Share Posted January 30, 2014 Hi, Is it possible to create voronoi pieces like this for a 3d geometry without inner pieces, but evenly sized and distributed: Does this require one to be able to uniformly scatter points on a 3d geometry which Scatter SOP can't? Either way I would appreciate some pointers. Thanks Quote Link to comment Share on other sites More sharing options...
rayman Posted January 30, 2014 Share Posted January 30, 2014 You can use remesh SOP + divide SOP with compute dual option on 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted January 30, 2014 Author Share Posted January 30, 2014 Thanks rayman, that's a neat trick. If someone has a way to also create a voronoi pattern this way, please let me know. I am just experimenting with an idea and it requires a voronoi diagram Quote Link to comment Share on other sites More sharing options...
papicrunch Posted January 30, 2014 Share Posted January 30, 2014 If you patern well the voro point in 2d, you can break objet like your pictures. Just create a grid and copy onto poly circle with 5 divisions for example then use this to the second input of the voro node Have fun 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted January 30, 2014 Author Share Posted January 30, 2014 Thanks papicrunch. No my object is not a grid unfortunately. I posted that pic because I couldn't find anything else But still grid or not, this would require a uniform distribution of points, right? How do you guys do this in Houdini since there is no way to do this using the Scatter. Scatter + Fuse trick works only to a degree and is not as high quality as a true uniform point scatterer. Quote Link to comment Share on other sites More sharing options...
anim Posted January 30, 2014 Share Posted January 30, 2014 I usually do just pointcloud lookip in pointwrangle or anything VEX/VOP based to separate points based on their mutual distances, then repeat it multiple times within Foreach SOP to get stable iteration and if you need it on the object just reproject it back every iteration 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted January 31, 2014 Author Share Posted January 31, 2014 Thanks anim, do you project with Minimum Position? Just moving points doesn't work great because they move outside the surface. It's hard to measure the distance on the surface. Also how do you know how much point you need in the first place to fill it? Or do you just fill the entire surface based on the number of points, without specifying a radius? It would be nice if we could just say, distribute points that are x unit away from each other using the Scatter. Quote Link to comment Share on other sites More sharing options...
freaq Posted January 31, 2014 Share Posted January 31, 2014 (edited) you can control the input points, so if you space them evenly you should be able to do it.(like for example a points from volume which would give you evenly sized cubes)to do it with scattered points, you can do a pretty dense scatter, and then do say 3 fuse sops in a row with the same size.it won't be exact but everything should be approximately the same size and seperation. Edited January 31, 2014 by freaq 1 Quote Link to comment Share on other sites More sharing options...
anim Posted January 31, 2014 Share Posted January 31, 2014 you can guess number of points by measuring total surface area and knowing the particle separation then just generate them with scatter and separate/reproject a few times as mentioned for reprojecting you can use Minimum Position VOP as you mentioned, or XYZ Distance VOP or Ray SOP 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted February 3, 2014 Author Share Posted February 3, 2014 Thanks guys. I did the relaxation technique of anim but I am getting holes that I don't know how to fill. It's working pretty good but I didn't guess the number, just used 10k points. Is it because I used more points than necessary? I would appreciate how to generate the points by measuring the surface area too. I am guessing that has to do with circles? Quote Link to comment Share on other sites More sharing options...
tjeeds Posted February 3, 2014 Share Posted February 3, 2014 Assuming you're doing this with a ForEach and a pcfilter, you can just increase the iterations on the ForEach. Also, this purely anecdotal but I found setting max points to 4 yielded the best results. As for the number of points you can turn on Compute Number of Points in the Scatter and set Points per Area instead of explicitly choosing the point count. relax_em.hip 2 Quote Link to comment Share on other sites More sharing options...
magneto Posted February 3, 2014 Author Share Posted February 3, 2014 Thanks tjeeds, mine was pretty much the same except pcfilter and the number of max points. I was using 2, so that I would only get the closest point within the threshold. In your file you are using 3 as max points but by 4, do you basically mean 3 of the closest points within the threshold? Because I tried 3, and I could spot 1-2 problem areas on a deformed grid, but still a great improvement. 4 seemed to work great. I set it to 5 because I somehow assumed averaging using the 4 closest seemed more logical. In any case thanks for your method. It's pretty smart Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted February 3, 2014 Share Posted February 3, 2014 (edited) Just for reference, in case you missed it , lets go back to the 2010 => http://schnellhammer.net/blog/2010/06/uniform-scattering-in-houdini/ Edited February 3, 2014 by mantragora 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted February 3, 2014 Author Share Posted February 3, 2014 Thanks mantragora, that looks good. Is that superior to this method? There must be a non-approximate method out there. I am sure someone has an OTL for this. Do you have something written using the HDK? Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted February 4, 2014 Share Posted February 4, 2014 (edited) Thanks mantragora, that looks good. Is that superior to this method? There must be a non-approximate method out there. I am sure someone has an OTL for this. I have no idea. It was 4 years ago and while I don't drink, I'm not getting younger also, so my memory is a little shady on this topic today. I didn't compared it with what you uploaded here. Do you have something written using the HDK? Nope. Edited February 4, 2014 by mantragora 1 Quote Link to comment Share on other sites More sharing options...
magneto Posted February 4, 2014 Author Share Posted February 4, 2014 I checked it out, it's pretty similar except it was averaging point positions manually instead of using pcfilter and was using the Ray SOP instead of the Minimum Position VOP which I assume wasn't available at the time. But is there a non-approximate method for doing this where you generate points instead of relaxing them iteratively? I was thinking maybe you could start with a single point and then add new points stemming from this point that follows the surface? Quote Link to comment Share on other sites More sharing options...
dpap Posted February 4, 2014 Share Posted February 4, 2014 If someone is actually gonna try to recreate what Cristian did but in HDK I suppose the following link would interest him http://graphics.uni-konstanz.de/publikationen/2009/capacityconstrainedpointdistributions/website/ It even has the C++ source code! I wish I knew how to compile this into a Houdini plugin/dso or whatever .... I beleve their results are amazing! 1 Quote Link to comment Share on other sites More sharing options...
edward Posted February 5, 2014 Share Posted February 5, 2014 I was thinking maybe you could start with a single point and then add new points stemming from this point that follows the surface? That sounds like stippling http://www.joesfer.com/?p=108 1 Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted February 5, 2014 Share Posted February 5, 2014 If someone is actually gonna try to recreate what Cristian did but in HDK I suppose the following link would interest him http://graphics.uni-konstanz.de/publikationen/2009/capacityconstrainedpointdistributions/website/ It even has the C++ source code! I wish I knew how to compile this into a Houdini plugin/dso or whatever .... I beleve their results are amazing! Hmmmmmmmmm... 1 Quote Link to comment Share on other sites More sharing options...
petz Posted February 5, 2014 Share Posted February 5, 2014 I checked it out, it's pretty similar except it was averaging point positions manually instead of using pcfilter and was using the Ray SOP instead of the Minimum Position VOP which I assume wasn't available at the time. But is there a non-approximate method for doing this where you generate points instead of relaxing them iteratively? I was thinking maybe you could start with a single point and then add new points stemming from this point that follows the surface? the only way i can think of how you would get perfect equidistant points is to use a circle packing. but if you don´t want any approximation this could become quite challenging on arbitrary 3D meshes if it´s done right... 1 Quote Link to comment Share on other sites More sharing options...
