Edge Displacement on fractured pieces
Tato
Thanks for the quick feedback and the tips. I`ll create another update soon( not right now as I don`t have working viewport on my laptop :/ ).
Edited by rayman
Also it would be great to have the node in wich i can put an other material with an other displacement for the extorior part and many thanks for your help!
Edited by Grucho
Thanks everyone for this thread. It's amazing. And Pavel, you are a genius! Thank you so much for sharing all your incredible knowledge. Just wanted to say I did a render test and did not have a problem with faceted normals. Keep it up man, you're an inspiration :)
Edited by juztn
Thanks!
I just did some tests an it seems that sops part is working fine (both displacement and uvs) on 13.0.310.
  On 5/17/2014 at 7:09 AM, Solitude said:
P.S. the sops version (displaceSop and uvs) under it don't seem to be functioning.
Pavel, this is great but not sure how the uv setup works. I have checked the code in the displaceSOP node but I'm not sure how the uv's are handled as it does not seem to take into account the projection done in the "uvs" section above.
I am also unsure about the boundGeo node. I understand this imports the geometry but at what point is the geometry assigned to the variable in the snippet? Hope that makes sense,,,,
edit: missed the boundGeo parameter. Just gonna try to link it to a node for testing instead :)
J
Edited by juztn
Hi All
Thats a great thread and great help so thank you all especially Rayman.
I am fairly new to houdini so I dont fully understand the setup as its still complicated for me.
I was wondering something and forget me if my idea is riduculous .
The voronoi fracture SOP has some functionality for adding interior detail.
Can we somehow take this functionality in the shader?
I dived inside the voronoi asset and it looks like its  doing it by sampling an SDF and applying noise based on a depth attribute. It looked simpler to me at least.
I cant figure out though how to implement it on a shader or if its possible .
Unforutnatley, the detail produced from voronoi fracture is only applied inside pieces, not on the outside edge of the pieces (correct me if im wrong), so I`think its not a solution.
You could create a rest position on your pieces, write an sdf of the geo to disk, then do volumesample of the sdf by rest position in shader.
Again thanks Pavel.
One question, I cannot figure out how to add an other displacement map for the outer face. I have tried to mask it without any success. I hope again you can help.
Thanks!
I'm more interested to make such displacement in SOP since we usualy export it for rendering in another software so I figured out when I convert the pieces to vdb and back to polygons with my initial geometry plugged on the second input of the convertVDB I get masks for edges, seams and interiors as well as good subdivision resolution for displacement but that happened on the first frame only and I'm not sure how can I use it in the Pavel's setup.
and here is the question: why we need to calculated the displacement on every frame. Isn't it possible to get that displacement on the first frame and use the transform from the lowres pieces to drive the hires ones?
  On 5/27/2014 at 11:56 PM, Grucho said:
Again thanks Pavel.
Thanks!
I`ll create some new example scenes by the end of the week (I hope).
Well, in sops we don`t have to. In shops on the other hand, we have geometry that is camera dependent, and we have to recompute displacement for every visible point = better detail.
Another approach is to execute displacement shop and bake it to UV`s. Then use this map as vector displacement inside your render of choice. This means nice uvs for each piece (or some ptex render hack).
I tried it and it seems to work. Unfortunately I don`t have access to full H license, so maps were really small and I decided to stop working on it.
Many thanks again!
The only problem I see (and it should be pretty easy to fix) is the same problem I was having in mine orginially. The normals on the outside of the sphere are faceted because they aren't be resampled from the original geometry. An attribvop + xyzdist + primtive attribute run over the verts can do it pretty easily.
Hey Solitude -- do you have an example of how this is put together?
Thank you, too, I really appreciate it!
I just did implementation of Normals correction inside shops.
Normals inside pieces are handled nicely from displace along normals node. For the outer normals on the other hand, we want to take original averaged normals from bound geometry and then blend again based on distance from bound surface. This means that additional setup outside snippet is involved, so I decided to keep it as simple as possible and dropped entirely displace along normals node and just recompute and blend everything inside snippet. This means old setup will still work, but new one handle normals differently.
I also updated overall code and replaced most of intersection functions with xyzdist instead(Thanks, Ian!).
Also I added internal vector space conversion, so no need for transform nodes inside shop any more.
There is still more work on sop part. Its not hard to recompute normals after displacement, but I want to do it inside snippet (:
I will post new version soon - just need more tests to ensure than everything is stable inside both contexts.
Cheers!
Edited by rayman
  On 5/29/2014 at 4:12 PM, Solitude said:
File attached in whatever state it is currently in. I got cut short last night while working on it.  Pretty sure I was messing with the normals for the inside faces last, so they're probably messed up still.
attachicon.gifvoronoi_edge_disp_v3.hip
Thanks! I`m really interested in your method.
  • 1 month later...
Wow. Nice to see this topic!
The question on first page was about my setup. I did not see this topic before, and I just surprized why nobody noted me about this topic because I am always open to explain any of my techniques.
It is just very cool research about several steps displacement for curved surfaces. I did not check current setup of Rayman, but I can suppose that it would be useful to calculate width of each step by original polygon size. Because each step means one access to pointcloud so we want to minimize that.
Also I use quaternions instead of matrix because it is vector4 versus vector9 or 16 for matix
Edited by almatea
  • Like 3
