clouds vortex
indienpz
For the dissipation, there is a parameter in the pyro solver that you can tweak that make the smoke live longer. For the expantion of the smoke, maybe you can create a succion force that will keep your smoke in a reasonnable range from your curve.
I cannot take a look at your scene for the moment, maybe you can check the vortex tab as javier proposed and see how it is build.
  • 1 year later...
