Strange flickering in flip fluid.
hermesnoel
Try to tweak parameters of the mesher. Maybe you can add more particles, so it has more source to create more stable topology. I couldn't run your scene properly (some missing files in setup). You can smooth the mesh after meshing or freeze the parts where is too much jittering (with help of timeshift/blend).
  • 5 years later...
