blending shapes with in-between steps ?
Hello,
I am trying to blend 2 simple shapes (2 curves with the same number of points) and get the in-between steps like the blend tool in illustrator would do.
The blend shape is doing the blend easily but how can I specify and keep the in-between steps geometry ?
(I am looking for the equivalent of the blend mode in C4D's Mograph cloner)
I am very new to Houdini, sorry if it is obvious, but I can't find it anywhere.
Many thanx.
Jérôme
post-11029-0-48595600-1393835302_thumb.g
Hey,
You could try animate the blend and add a Trail sop set to "Preserve Original" and use:
Trail Length - set it to how many steps you want, but you'll need to ensure there are enough frames to match.
Trail Increment - set it to 1 and it will leave a copy on each frame, set to 2 to skip every other frame etc.
Cache Size  - usually set it to the same value as trail length.
Hope that helps!
Matt.
Thanx a lot guys, works perfectly of course.
I locked the trail node with a time shift, is there a better way ?
thx
J
Thats perfectly fine, or you could use the Lock-flag (red) on the node as well. Whatever you prefer really.
