FR3D
hello
here is one of the project i did fully in houdini.
the mosque was procedurally modeled in houdini thanks to copy,cookie, and instancing.
render in mantra with PBR.
i used houdini compositer for the depth of field (Pz)
the idea was to put the 99 names of God on a traditional mosque in dubai.
https://vimeo.com/89587482
Edited by FR3D
thank you.
sorry to disappoint you guys but the calligraphy is actual geometry.
no smart technical trick here :(
illustrator file cleaned and extruded in Houdini
i wish i knew how to make a displacement that extreme,with clean angles, and to the side of the displacement.
as for the wall texture it is simple bump.
here i put some screen shot so you can see for yourself.
The whole structure was very light, unfortunately i had to apply a divide node due to texture tearing at render time.
reference:
post-7936-0-33781500-1395571960_thumb.jp
post-7936-0-79391400-1395570354_thumb.jppost-7936-0-91765400-1395570356_thumb.jppost-7936-0-76541700-1395570359_thumb.jppost-7936-0-54846400-1395570363_thumb.jppost-7936-0-96285700-1395570365_thumb.jppost-7936-0-75488900-1395570368_thumb.jppost-7936-0-86754200-1395570370_thumb.jppost-7936-0-63209600-1395570374_thumb.jp
Edited by FR3D
  • 2 weeks later...
  • 6 months later...
