BGEO TO PRT
Dim
Hey all
So quick question.
Has any body been able to convert bgeo to prt?
I've seen a couple PrtRop Driver nodes floating on the net but unfortunetly I cant seem to find a version for my Build of Houdini. Running Version 13.0.376 far as I understand its a VC11 build and the PrtRops i've found are VC9 builds.
Reason is I need to port particles to Max/Maya to render in Krakatoa,but need to make sure my Colour,Velocity and Position channels are intact.
Does anyone know if there's a script or anything that can convert bgeo to prt and were can I get my hands on it.
BTW I have no scripting knowledge
Thanks guys
  • 6 months later...
Next Limit has an up to date plugin, although I'm unsure whether you can download it if you are not a customer.
There is an older opensource plugin from xionmark, but I don't know if it will compile any more: http://forums.odforce.net/topic/16111-realflow-houdini-12-sops-update/
Argh, first we lost emails to topreplying, and now the forums are slipping too. ;)
