Malcolm Zaloon Posted May 12, 2014 Share Posted May 12, 2014 Hello guys! I´m making a scene with a open bottle, falling, but when i simulate, the liquid inside goes up, and exits the bottle from up... i believe this is happening because there is no "vacuum" between bottle and liquid... there is some approach to correct simulate a open bottle dropping quickly and looks like real thing? (Liquid follow bottle because vacuum) thanks. attached a image of liquid... Quote Link to comment Share on other sites More sharing options...
Skybar Posted May 12, 2014 Share Posted May 12, 2014 Not sure what you mean by vacuum. Are you dropping it in space? Quote Link to comment Share on other sites More sharing options...
Malcolm Zaloon Posted May 12, 2014 Author Share Posted May 12, 2014 (edited) the vacuum between bottle and liquid.... because, in real world, when you drop a open bottle with liquid, the liquid tends to follow bottle because of internal pressure (vacuum). this effect occur on bottom of bottle because is "sealed". this is the perfect example of what i want to achieve... yes.. the liquid is not forming a "empty space" on bottom, because there is "sealed". Edited May 12, 2014 by Malcolm Zaloon Quote Link to comment Share on other sites More sharing options...
Skybar Posted May 12, 2014 Share Posted May 12, 2014 Looks just like gravity to me, not vacuum or pressure. As for replicating that video though, you could try to sim to bottle first. Then sim the flip and copy the vel from the bottle to the particles. That should make it go downwards together like that. Or you could as well just fill the bottle up and put an invisible lid on it. Its CG, its okay to cheat. Quote Link to comment Share on other sites More sharing options...
eetu Posted May 13, 2014 Share Posted May 13, 2014 the vacuum between bottle and liquid.... because, in real world, when you drop a open bottle with liquid, the liquid tends to follow bottle because of internal pressure (vacuum). Yes this "virtual vacuum suction" would be the case if you are trying to move the bottle faster than freefall acceleration. If you just let gravity do its thing, it should affect both bottle and fluid the same, right? Quote Link to comment Share on other sites More sharing options...
Malcolm Zaloon Posted May 13, 2014 Author Share Posted May 13, 2014 Yes this "virtual vacuum suction" would be the case if you are trying to move the bottle faster than freefall acceleration. If you just let gravity do its thing, it should affect both bottle and fluid the same, right? yeah, this is the idea.. faster than freefall, but even this, in real thing the liquid go with bottle at low speeds, like a hand pulling bottle against a table. Quote Link to comment Share on other sites More sharing options...
old school Posted May 14, 2014 Share Posted May 14, 2014 It's not so much vacuum but the air pressure above the fluid. One approach is to fill the entire bottle with particles. The water particles have a density of 1000 and the air particles have far less density, try values of 1 to 10. You can use two particle emitters on the first frame and use the density settings on the Fluid Source SOPs to set this up. Quote Link to comment Share on other sites More sharing options...
