tomwyn Posted May 14, 2014 Share Posted May 14, 2014 Hi all, Is there a way to link & sequentially export Dop I/O rops in seperate Geo nodes (see example image where I have 3 dopnets, with 3 separate dop i/o nodes in their own geo nodes)? Or is there any other clever ways to do this? (I'm not that proficient with the command line) Thanks! Quote Link to comment Share on other sites More sharing options...
Skybar Posted May 14, 2014 Share Posted May 14, 2014 I usually go the the Out-context, and either use Fetch ROP or Geometry ROP to choose what I want to write to disk. Create as many of those as you want, and then use a Merge ROP and merge them all together. On the Merge ROP you can now choose to render Frame by Frame, or Node by Node. 1 Quote Link to comment Share on other sites More sharing options...
wateryfield Posted May 15, 2014 Share Posted May 15, 2014 Good tips! Skybar. Quote Link to comment Share on other sites More sharing options...
