jwhit6142004 Posted May 20, 2014 Share Posted May 20, 2014 I am trying to create an explosion, and ive messed with multiple settings, but i seem to be stuck on how to get the explosion to light u, have the fuel go up and start the smoke, but then it keeps emitting fire much like an ongoing fire. Ive included a video of it and my HIP file. FireTest_6.movFetching info... Ver_1.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
chrobak Posted May 20, 2014 Share Posted May 20, 2014 check a few things. in your fuel source, if you clicked the out of the box explosion in houdini, is animated. shift click the scale source volumes i htink it is and animate it as you wish. also in your pyro solver the gas released is animated as well. try using both attributes together to get the look and if you animate them to zero it should be fine. sorry i cant work on your file my houdini isnt open at the moment. last thing you can do it animate the fuel attribute under the create fuel volume in the sop of the emitter. let me know if this works, Mike Quote Link to comment Share on other sites More sharing options...
jwhit6142004 Posted May 20, 2014 Author Share Posted May 20, 2014 chrobak,I actually animated both of those attributes myself. Thats why I dont understand why its still not going out. I have them both set to go to "0" quite early on in the explosion. Quote Link to comment Share on other sites More sharing options...
Skybar Posted May 20, 2014 Share Posted May 20, 2014 Decrease or even set the "Fuel Inefficiency" to 0. You have it on 0.75 right now, which basically means that 75% of the fuel is kept and will keep burning. If you set it to 0, all fuel is "used up" when it has burned and there won't be anything left. At the same time you can also increase the "Burn Rate", which tells it how much fuel to burn per second. So if you have 0.9, you will still have 10% fuel left after one second. If you only want that initial explosion and no "afterburning" at all, a Burn Rate of 1 and Fuel Inefficiency of 0 will use all the fuel at once, for example. 3 Quote Link to comment Share on other sites More sharing options...
jwhit6142004 Posted May 20, 2014 Author Share Posted May 20, 2014 skybar, Thank you, that was the solution Quote Link to comment Share on other sites More sharing options...
