exel Posted May 27, 2014 Share Posted May 27, 2014 (edited) I was doing some Pyro stuff and got majorly sidetracked, this is what came out: I'm bummed the compression is so bad, I tried a lot of things and just couldn't get it looking good in Vimeo, the original renders look so much prettier. Edited May 27, 2014 by exel 1 Quote Link to comment Share on other sites More sharing options...
exel Posted May 27, 2014 Author Share Posted May 27, 2014 also this. Quote Link to comment Share on other sites More sharing options...
edward Posted May 27, 2014 Share Posted May 27, 2014 I'm bummed the compression is so bad, I tried a lot of things and just couldn't get it looking good in Vimeo, the original renders look so much prettier. Yeah, I hate video encoding as well. It *always* takes me hours (if not days) before I find the right settings every time. Do the encoded videos look better prior to uploading? If so, what is your original resolution? It sounds like vimeo won't provided an "HD" version unless it's over 720x720 pixels. I wonder if just upscaling the images before encoding makes any difference. There's some guidelines in vimeo here: http://vimeo.com help/compression Quote Link to comment Share on other sites More sharing options...
exel Posted May 27, 2014 Author Share Posted May 27, 2014 Yeah, I hate video encoding as well. It *always* takes me hours (if not days) before I find the right settings every time. Do the encoded videos look better prior to uploading? If so, what is your original resolution? It sounds like vimeo won't provided an "HD" version unless it's over 720x720 pixels. I wonder if just upscaling the images before encoding makes any difference. There's some guidelines in vimeo here: http://vimeo.com help/compression Thanks Ed, yeah it's hit or miss for me. The original renders are 1280x720, but they have a little noise in them from the environment light and PBR render, maybe it's causing some kind of interference. Quote Link to comment Share on other sites More sharing options...
Guest tar Posted May 27, 2014 Share Posted May 27, 2014 (edited) try running them through a denoiser, like Neat Noise, before uploading. It's cool trick for quick-clean renders too That noise should be using up all the compression. Edit: added a Neat version of your Jpeg'd frame. Compression a non-Jpeg would be better too. Edited May 27, 2014 by tar Quote Link to comment Share on other sites More sharing options...
Skybar Posted May 27, 2014 Share Posted May 27, 2014 Cool stuff! Getting sidetracked in Houdini can be very productive some times Quote Link to comment Share on other sites More sharing options...
amir7500 Posted September 6, 2014 Share Posted September 6, 2014 nice tricks for the begginars... Quote Link to comment Share on other sites More sharing options...
traiano Posted November 6, 2014 Share Posted November 6, 2014 nice Quote Link to comment Share on other sites More sharing options...
