fragmentzero Posted June 7, 2014 Share Posted June 7, 2014 Hello, I created few custom shelf tools for learning purposes and added them in tab menu of various contexts. I have deleted most of them from the shelf but all of them still exists in the tab menu. How can I remove them? Also how can I remove the tab menu itself or rename it? Thanks Quote Link to comment Share on other sites More sharing options...
mangi Posted June 7, 2014 Share Posted June 7, 2014 Hi Go into the Houdini Folder here: C:\Users\jumangic\Documents\houdini13.0 this is where I have mine You can delete the entire folder and it will rebuild the desk top. From scratch. C:\Users\jumangic\Documents\ delete "houdini13.0" or "houdini12.0" etc. which ever one you see in this folder Cheers mangi Quote Link to comment Share on other sites More sharing options...
Guest mantragora Posted June 7, 2014 Share Posted June 7, 2014 (edited) When you are creating shelf tool, make sure that you save it to custom "*.shelf" file. All the settings, code etc. will be stored there. If you didn't created custom file, than it was stored in the "default.shelf" file. Somewhere in this file there will be created XML section similar to the one described here. If you still have you shelf in Tab menu, that means that it wasn't removed from there, so remove it yourself. Make sure that you create backup of this file, in case you mess something. So if you have your own shelf file, structure should look like this: <?xml version="1.0" encoding="UTF-8"?> <shelfDocument> <!-- This file contains definitions of shelves, toolbars, and tools. It should not be hand-edited when it is being used by the application. Note, that two definitions of the same element are not allowed in a single file. --> <toolshelf name="mantragora_utils" label="Mantragora Utils"> <memberTool name="Foo0"/> </toolshelf> <tool name="foo0" label="Foo 0" icon="PLASMA_App"> <toolMenuContext name="viewer"> <contextNetType>SOP</contextNetType> </toolMenuContext> <toolMenuContext name="network"> <contextNetType>SOP</contextNetType> </toolMenuContext> <toolSubmenu>MANTRAGORA/Shelf</toolSubmenu> <script scriptType="python"><![CDATA[import fooUtils as mantragora reload(mantragora) mantragora.Tools.Foo()]]></script> </tool> </shelfDocument> Of course if there is more than one tool in the shelf, there will be more <memberTool></memberTool> and <tool></tool> sections there. <toolSubmenu></toolSubmenu> is responsible for adding it to the custom Tab menu, <toolMenuContext></toolMenuContext> is responsible for displaying it in specified view type. So probably it's one of those that was left behind when you removed you shelf tools. Edited June 8, 2014 by mantragora Quote Link to comment Share on other sites More sharing options...
fragmentzero Posted June 8, 2014 Author Share Posted June 8, 2014 Thanks for the tip in making a custom shelf. It's good to separate new tools from default shelf. And editing the shelf files worked too. Thank you. Quote Link to comment Share on other sites More sharing options...
