Juraj Posted June 9, 2014 Share Posted June 9, 2014 Hello, I'm novice to houdini and I'd like to have particles killed after some time elapsed after collision happened. What would be the correct approach? Should I try to do it with events? Or can it be done with Kill POP using VEXpression rule? Thanks Quote Link to comment Share on other sites More sharing options...
wateryfield Posted June 10, 2014 Share Posted June 10, 2014 (edited) You can use pop kill and pop collision detect. Collision will create hitnum and hittime attribute. dead = i@hitnum > 1 & @age - @hittime > 1; The hittime will be 0 if collision not happen. You must use if condition It will delete the particle 1 second after collision. Hope it help. Edited June 10, 2014 by wateryfield Quote Link to comment Share on other sites More sharing options...
Juraj Posted June 10, 2014 Author Share Posted June 10, 2014 Hi, thank you for your response. I noticed that popsolver already created attributes hitnum and hittime. However when I am checking those attributes in details view for certain particle, then on time when collision happens hitnum is set to 1 but next frame it is 0 again. And the hittime seems to behave strangely. It increments only after some frames and sometimes even decreases. To detect whether collision occured maybe I can check whether hitpos is not zero. Quote Link to comment Share on other sites More sharing options...
