Calculation the angle of the polygon
Guys.
Help me a trigonometric functions problems, i have to calculation the angle of the polygon.
The expression  angle = acos (dot(N(V1),N(V2)))  can't get the degrees great than 180, i have a polygon interior angle great than 180.
How can i judge when negative the angle, I totally forget the  dot product principle.    :D
Thanks.
angle_between_vectors.hip
You need to check if two adjacent edges are convex or concave.
I used dot product between normal and cross product for that. I also modified how to compute angle between edges. I used neighbour edges instead of edge and normal becouse you got some strange results on some points.
Look at file.
Thanks!  Pezetko.
It really works great.
I have to review the dot product and Normal .
